Largest tires on TRD pro stock rims ?
shaunmorgan
Shaun
toronto
2024 Tacoma TRD pro
What is the largest possible tire I could go for my 2024 trd pro on its stock 18” rims and ride height ? (willing to remove mud flaps and plates if needed)
Know this question has been asked multiple times for many trim levels but not seeing much about TRD pros .
Open to any insight and advice & would love to see other trd pros set ups especially if on 18’s . Thank you so much in advance and looking forward to connecting with the Tacoma community .
2024 Tacoma Largest tires on TRD pro stock rims ? IMG_4917
JayZap
Weston, FL
2025 Tacoma Trailhunter
The TH and TRD PRO share the same offset so all that data in the other threads carries over.
In summary, largest tire you can throw on is 295/70s if you remove the crash bar and oem mudflaps. I still had tini tinrub until I moved up the caster slightly but that’s because I kept my ARK low profile flaps which consumed about 2mm of clearance. Once I lifted my TH another 1.5 inch from stock, caster back at nominal with flaps, no rub. 295/70 spare won’t fit under the bed.
I also initially tested 285/70s. No rub with everything OEM in place. 285/70 spare fits under the bed but just barely but wouldn’t trust the chain hoist holding that heavy wheel on bumpy roads.
Here is 295/70R18 AT4 e loads compared to stock tire size:
2024 Tacoma Largest tires on TRD pro stock rims ? IMG_5953
2024 Tacoma Largest tires on TRD pro stock rims ? IMG_5954
2024 Tacoma Largest tires on TRD pro stock rims ? IMG_5955
Ltrain
Lee
Illinois
Briscoelab
MN
25 Tacoma Trailhunter, 25 LC250
275/70r18 fit nicely. I think that or the various 285 width tires are the sweet spot for these trucks.
fightforfood247
Matt
Syracuse ny
2024 Tacoma trd off road
Saving this to comeback and reach out to you to upgrade my TH tires
TRD DON
Don
Bowling Green, Ohio
2025 Tacoma TRD Pro
D
did the 285/70/18's fit with the Oem mudflaps at full lock? I'm debating 275/70 or 285/70's for my Pro but trying to keep the weight gain as minimal as I can
shaunmorgan
shaunmorgan
Shaun
toronto
2024 Tacoma TRD pro
D
did the 285/70/18's fit with the hem mudflaps at full lock? I'm debating 275/70 or 285/70's for my Pro but trying to keep the weight gain as minimal as I can
I ended up going with BFG K03 in size 285/70R18 on stock Trd pro rims . I did remove crash pad and mud flaps because I thought I’d need to for clearance but there’s plenty of room I could’ve left them on. Noticed jump in MPG but worth it for the look in my opinion . Ride I wouldn’t say is any rougher or louder than stocks either which I was worried about !
TRD DON
Don
Bowling Green, Ohio
2025 Tacoma TRD Pro
hmmmmmm... do you think a 275/70/18 on a trd pro would clear without trimming?
shaunmorgan
shaunmorgan
Shaun
toronto
2024 Tacoma TRD pro
100% certain 275 would fit without any crash pad removal , mud flap removal or rubbing .
