Benny’s Build : Solar Octane, Hybrid, TRD Off-Road Premium
Benny
Benny
Jay
Oregon
A Taco, an IBEX and a Revolver
BAK Revolver X4ts tonneau cover & the Küat IBEX bed rack
I got the BAK Revolver X4ts for Christmas shortly after I got my Taco. I like Revolver for its low profile when closed, rigid metal frame and roll up feature that doesn’t impede on bed space or block the rear window or rear view camera when open. I had been looking at Küat IBEX (SKU: IBEXA1) for a while and didn’t pick one up until they had an adapter that would fit the Revolver X4ts - that was finally released a few months ago and is the Retractable Tonneau Adapter - IBEXA1/A2/A3 - Compatible with Retrax, LineX, and BAK (SKU: AIXRMMS). I love the finished look of the IBEX rack, no exposed bolts or rivets, and a well built out ecosystem of accessories that uses Küat’s t-slot system.
The Adapter
When I got the my tonneau cover, I emailed Küat and asked if they had an adapter - and Küat said “Sorry no…” Fast forward a year and we have this. The adapter box actually said “Jeep Gladiator” on it - which has been out for a while. So maybe the just had to get some testing done. The box shorted me 3 T-Slot nuts, but Küat was kind enough to 2 day ship replacement bolts.
The IBEX adapter rails sit on the top of the Revolver X4ts rails and are locked down by 3 pairs t-slot nuts and bolts. I used a little removable thread lock to help secure the rails. The IBEX rack will sit on top of the rails and be secured from the inside.
Lots of videos on YouTube of the IBEX being assembled, so no need to recreate content. It’s a good looking rack!!
Match made in heaven in my humble opinion.
Rump view.
This is one of 6 attachment points on the adapter rails to attach to the IBEX rack (3 on each side). Normally any bolts the attach the IBEX to the truck, Küat provides security bolts that have a pin in the socket, preventing any normal Allen wrench from removing the bolts. This is NOT the case with the adapter. Hopefully Küat will make security bolts available soon.
Here is a close-up Revolver T-Slot Rail (bottom), Küat’s adapter rail (middle - you can see the flange to the right), and the IBEX rack sitting on top of everything.
Here is a wider view of the rack sitting on the adapter rail.
And the moment of truth
Sucess! A tonneau cover compatible with a bed rack!
Close-up of the rolled up Revolver tonneau inside the IBEX frame, snug, but it clears the frame and should clear Küat’s MOLLE panels.
Photo Gallery
Final Thoughts
Although I like the look of the full width MOLLE panel, I will probably go with 3 of the narrow panels. That way I can still access the truck bed from the sides of the truck.
You probably will be limited on what you can mount on the inside of the MOLLE panels due to the roll-up nature of the tonneau cover… so no RotopaX on the inside.
The Revolver rails and IBEX adapter raise the rack above the roof of the cab.
I eventually plan on getting the crossbar risers, so not a big deal and it gives me a little extra clearance over the antenna. I would also like to add the Küat DEK with the Diode Dynamic lights. (Küat if you are reading, I’d be happy to review it!)
Another reason I chose the IBEX was it cleared my digital rear view camera.
Just a bit of the vertical bars on the edges of the camera’s field of view.
Overall an easy installation, with straight forward instructions. Küat customer service was great and got replacement parts out quickly. Really happy with my tonneau cover and bed rack. Küat makes a premium product, solid, well engineered and well designed. BAK Revolver fits my needs perfectly, some added bed security but gets out of the way when I actually have to haul something.
If you are looking for a tonneau cover and bed rack combo, this is a great option.
nurp42
TRD PreRunner
'24 PreRunner
The Adapter
Rump view.
Photo Gallery
Final Thoughts
Looks great——nice job (y)
emidyl
Henry
Toronto
N400 Sport Prem
thx Benny, glad it clears the full roll position. Gonna order mine when the weather warms up.
cthoma70
Chester
Kentucky
2025 Tacoma Off Road Hybird
BUILD UPDATE: Benny gets Running Boards Not Rock Sliders
Well after some consideration I went with running boards and not rock sliders.
My initial plan was to go with NYTOP’s 2024 Tacoma Rock Sliders which have a great, integrated look - and what seems to be a small step area:
I really like how they “fit” the new Tacoma, and they did a great job designing them. But….
1) The first knock was these rock sliders are about 3-4 months back ordered.
2) Second, shipping was an addition $500+ putting the final price around $1,900.
3) Finally I had to ask myself “Do I really need rock sliders?” I like the idea of them but in reality I won’t be rock crawling anytime soon in my brand new Taco. ?
So a little reality check is always good when shopping. Yeah this is mostly a commuter rig, and he’ll get to do some fun off road stuff every now and then. Running boards win!
I was just starting to look for some when I decided to look on the for sale area of our forum.
Fortunately, found another owner selling his Toyota TRD Cast Aluminum Running Boards that came with his truck.
My Pros:
-OEM “look” with TRD branding
-Good Price at $800 (Retails $900 to $1,400)
-Easy install
-Should offer some added body panel protection
-Solid stable platform, with textured non-slip surface
~More practical for my needs
-My Cons
-Not as sleek as I was originally looking for.
-A touch heavy, but they are cast aluminum.
I can’t seem to escape the TRD branding ?
Forgot to add pictures of them mounted on the truck…
The look like they stick out a lot because the panel curved in ward,
but in reality they are pretty in line with the fender flares.
I really like these.
JPI
2026 TRD Off-Road 4WD Double Cab (5' Bed)
The Adapter
Rump view.
Photo Gallery
Final Thoughts
Wow, this is awesome. I bought the same cover and was thinking about Elevate bars, but this looks like a much better option.
Have you done much digging on the crossbar riser kit yet? You mentioned the cover should clear the molle panels ...does this include the front molle panel required by riser kit? From the pics it looks like it should, or worst case the cover rolls up an inch or two less.
Benny
Benny
Jay
Oregon
That’s a good question… the strap latches for the tonneau cover sit right at the top of the bed.
I wondered if Küat’s front MOLLE panel would interfere with the securement of the tonneau cover. Thankfully Küat released this more minimal stabilizer bar:
Küat Part Number: 040-039-00-04
The bar should be able to install it just below the rear window slider, thereby clearing the tonneau cover latches. I don’t think I would ever use the front MOLLE panel given the set-up I’m running, and a bonus - this weighs less than that front MOLLE panel.
I eventually want to add, 3 sets of the Narrow, Full-Height MOLLE Panels, 2 Pairs of the Crossbar Risers and the DEK, Direct-Mount Roof Top Platform with the Diode lights.
JPI
Nice. I wouldn't use that front panel either. Kuat says that front stabilizer comes standard now. I saved some money ordering from rerack. Hopefully it's included!
I been looking at the DEK too. I haul around a 16 foot kayak quite a bit. It's hard to beat a bed extender for local trips, but long drives or hauling multiple yaks i'll need a good way to get them up top.
Benny
Benny
Jay
Oregon
@JPI - All Küat IBEX racks now ship with the stabilizer bar. I contacted Küat today asking if my rack was missing it from the packaging. They told me I had an earlier rack that didn’t ship with them. So Küat is sending me one for FREE! Been really happy with Küat’s Customer Service!
Benny
Benny
Jay
Oregon
Added the ARB Rear Recovery Hooks 🪝
JPI
Well damn lol! I had already ordered one. Maybe I'll see if I can get some other freebies. Good news is I got the rack setup with crossbar risers. Super solid, high quality stuff... except for that stabilizer, I've got some issues to work around, but doesn't sound like you did.
Two issues I found...
  1. The M8 bolts that attach the stabilizer to the rack, goes completely through the T-Nut and into the rack frame on the other side. I added an extra washer to fix it. I got some scuffs but no biggie.
  2. The left side of the stabilizer (the side with a long slot) bent out on me. The directions say to torque all bolts to 21 Nm. I got to 17 nm and saw it drop to like 16, weird but kept going (oops)... got to 19 and it dropped again, pulled the wrench off to see better and saw that it widened that slot and bent my washer. Good news it went back to normal when I pulled it off
    The nut on the left side (closer to the edge) got to 21 nm no probs...
    Thinking I'll try some wider washers, maybe add a star washer for grip to prevent spreading. Or maybe fill these gaps with something to prevent the inner bar from expanding.
Benny
Benny
Jay
Oregon
Facebook Marketplace for the win!
TRD Pro Wheels, Tires, TPMS Sensors & Black Lug Nuts = $800.
I’m really appreciating this trickle-down economy from the Pro Owners. 😆
Benny
Benny
Jay
Oregon
Looking Fresh with a bath and New Kicks!
Really 🧡 the TRD Pro wheels, easy fit since my Off-Road wheels are 18” as well.
Yes the OEM Goodyear Wranglers are garbage but it’s nice sitting an inch taller and filled out wheel wells.
