portalhunter
Bob
Wrote up a long-form review of the Triple-R Linear-18 Elite+ grille kit after four months on my Trailhunter. Triple-R is UK-based and doesn't yet operate a US dealer network, so this kit hasn't surfaced in most 4th Gen threads. Triple-R reached out about using my Trailhunter as a test vehicle for R&D on this kit, and the hero photo below is now their official launch shot for the TRD Pro and Trailhunter grille kit. Posting the highlights and install notes here because the CAN bus integration story on the 2024+ platform is worth knowing even for owners who run a different bar.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 46586-ff5b06845b0d3ff73371e5b65ca8a801
What made this kit interesting
One small feature on the TRD Pro and Trailhunter factory grille bar matters more than you'd expect once you start researching aftermarket upgrades. It turns on automatically when you flip the stalk for high beams. Pull the stalk, bar lights up with your brights, with nothing to do from the driver seat. Swap in any drop-in aftermarket bar on this platform and you lose that. The signal isn't an analog 12V wire anywhere in the engine bay. It rides the CAN bus as a digital message, which means aftermarket kits can't see it without a decoder. So every replacement kit ends up shipping with a cab switch and a relay harness you mount somewhere on the dash, and you reach for that switch every time you want more light.
Triple-R out of the UK has built a module called the CANNY Interface that reads the 2024+ Tacoma's CAN bus directly and closes a 12V trigger circuit when it sees the high-beam message. That's what caught my attention. Factory behavior is preserved on the driver side, with the Linear-18 Elite+ lamp in the grille instead of the OE bar. No switch in the cab, no wire through the firewall, no thinking about it after install day.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 46587-b7bf115f9c9099a3dca25b4029589989
Quick word on Triple-R
Triple-R is the US arm of Lazer Lamps, a UK lighting outfit headquartered in Harlow, Essex. Ben Russell-Smith started Lazer in 2010 after running exterior lighting projects at Nissan's European Technical Centre and Ford of Europe. Design, photometric testing, and assembly all happen at the UK facility. The racing pedigree compounded fast: 30+ vehicles ran Lazer-built lights at the most recent Dakar Rally, including Toyota Gazoo Racing's Hilux T1+. The same optics survive King of the Hammers and the Baja trophy-truck circuit. They don't operate a US dealer network and barely advertise stateside, which is why their name rarely comes up in aftermarket threads.
The Linear-18 Elite+ in this review uses the same optics platform as those rally lamps, repackaged with 2024+ Tacoma grille brackets and a one-lamp wiring kit.
The CAN bus problem and the CANNY solution
Modern vehicles like the 2024+ Tacoma don't run a simple 12V wire to things like the headlights anymore. Everything is managed through the CAN bus, a two-wire digital network the ECU uses to talk to every module on the truck. Flip your high beams and the ECU sends a digital message across that network. Aftermarket light bars that assume an old-school analog trigger exists can't see the message, which is why cab switches are the default workaround.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 03-factory-bar-canbus-modul
The factory grille bar pictured above has its own CAN bus module built in, which is why disconnecting it doesn't throw codes and why aftermarket wiring gets complicated on this platform.
CANNY is a sealed decoder module from Triple-R's sister brand Lazer Lamps. It sits between the truck's CAN bus and the bar's trigger leg, reads CAN frames, filters by message ID, and closes a 12V relay when it recognizes the high-beam event. Two SKUs at checkout with the same end capability:
- Direct Connect ($195, IP68) splices directly into the two CAN bus wires. Lowest cost, rated for engine bay mounting.
- Contactless ($245, IP64) slides between the CAN bus wires and reads signals inductively, held in place with a zip tie. No factory wiring is cut. Good pick if you lease the truck or plan to resell.
CANNY also supports up to four independent 12V outputs, remappable via Bluetooth through the CANNY app. I've only used the high-beam trigger so far, but owners could map reverse to rear aux lights, position lights to a DRL channel, or brake and turn signals to chase lights for trail running. Firmware updates happen over Bluetooth too.
Triple-R has a CANNY HP version coming with four 20A-supported circuits. Within that 20A-per-circuit limit, you could wire the lamp power directly to CANNY instead of running a separate relay harness back to the battery. Not shipping yet as of April 2026, worth watching if you're planning a larger build.
The light bar itself
Linear-18 Elite+ is the dual-color version of the Linear-18 platform. 36 white LEDs at 5000K and 18 PC-yellow LEDs in the same housing, switchable on the fly via a momentary button input or a Bluetooth button paired to CANNY. A memory function recalls your last selection on startup. Three modes:
- White: 14,850 lumens full output, broad beam spread for open desert and trail driving
- Yellow: 6,150 lumens PC-amber, optimized for dust, fog, and snow
- Combo: all 54 LEDs active, 21,000 combined lumens with a warm bias that balances throw and peripheral visibility
Same location, same camera angle, three modes:
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 04-mode-whit
White mode at 5000K, full 14,850 lumens, broad spread for open desert and trail running.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 05-mode-yello
Yellow mode (PC-amber): cuts through dust, fog, and snow without scattering back into your eyes the way white light does.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 06-mode-combo
Combo mode: 36 white + 18 yellow LEDs all active, 21,000 combined lumens with a warm bias that balances distance throw and peripheral visibility.
Yellow mode was the feature I didn't know I wanted. Living in Arizona, dust plumes from lead vehicles turn white light into a wall because the particulates scatter the beam right back at you. Yellow cuts through that the way fog lights do. First time I ran it behind another truck on a dirt road the difference was immediate.
The lamp is IP68 rated, CAE-optimized heatsink, polycarbonate lens that Triple-R calls unbreakable and backs with a lifetime warranty. Five-year warranty on the bar and all hardware. Anti-theft fasteners on the brackets with a keyed Allen tool are a nice touch for a lamp that lives behind an open grille.
Install
About 45 minutes on the grille side for someone comfortable with basic hand tools. Three 10mm bolts hold the grille to the core support. Unplug the fog lights and parking sensor harness on each side, release the retaining clips along the bottom edge, and the whole grille assembly slides forward and off.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 07-grille-removal
Triple-R ships two composite brackets coded LHOB (left) and RHOB (right) that engage with the factory mounting points on the grille frame. Anti-theft fasteners secure the bar, and Triple-R recommends thread seal compound with an 8 Nm torque spec.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 08-brackets-mounted
Cover pieces snap over the bracket ends for a clean finished look. Reverse of removal to reinstall.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 09-install-complet
CANNY takes another 30-60 minutes depending on which connection version you picked. Mount the sealed module, wire it between the CAN bus and the bar's trigger leg. Robert at Triple-R was straightforward about this: he would not call the CANNY side plug-and-play. Once it's in though, the end result matches factory behavior exactly.
One useful thing worth knowing before you touch any wire: unplugging the factory OEM light bar does not throw any codes on the 2024+ Tacoma. You can leave it disconnected indefinitely and the truck won't complain, which gives you room to take your time on the wiring side without dash alerts.
The honest caveat
E-mark certified for road-legal auxiliary use in Europe, not SAE or DOT certified for US road-legal status. In US terms this is an off-road auxiliary light. Worth knowing if street-legal auxiliary use matters to you.
Where to see the rest
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color 10-night
Full writeup with install photos, night-mode beam comparison shots for each mode, spec sheet per mode (lumens, wattage, current draw), and a CAN bus trigger explainer that goes deeper into how CANNY works on this platform:
https://truck.bdigitalmedia.io/blog/triple-r-linear-18-grille-light-bar/
Install video is on Triple-R's YouTube channel if you want to see it end to end: youtube.com/@TripleRLights
Discussion
Happy to answer questions on the install, the CAN bus trigger behavior, the yellow mode in dust and fog, or the CANNY mapping options I haven't tested yet. Robert at Triple-R has been good on technical support and I can relay deeper questions if they come up. The CAN bus story on the 2024+ platform also applies to anything you might want to wire up beyond a grille bar (rock lights, rear aux, brake-triggered chase lights), so worth knowing whether or not you end up running this specific kit.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Amazing truck you’ve had built out. I’m jazzed to see more on the lights and suspension…will need to stalk your other posts.
By chance will you have the truck at Overland Expo West in Flagstaff (May 15-17)? Wife and I will be there.
portalhunter
portalhunter
Bob
I will! I don’t think the truck is gonna be in a booth but I’ll be at the expo headed in the general area for the weekend
lauren01
Lauren
Ventura, CA USA
Groovy. Maybe we’ll see you there. Would be fun to say hi at least.
n118nw
San Antonio TX
Taco Supremium
Install
The honest caveat
Discussion
Very nice write up. I have the exact same bar in my grill, however I went overboard with 3d printing a bracket to utilize more of the OEM mounts. I found just using the ones on the sides resulted in a lot of vibration since the grill itself is a tad flimsy. I also eliminated the CAN bus by utilizing a module to translate the momentum switch into a toggle switch and used a TRD Light Bar switch from the Tundra, and then rigged a blank momentum switch next to the aux lighting buttons to toggle modes (the black one next to Aux3). Definitely overkill, but I wanted it to look close to OEM as possible.
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color IMG_8059
2024 Tacoma Triple-R's Linear-18 Elite+ grille kit on a Trailhunter: install, CAN bus, dual-color IMG_8347
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Bro! Great write-up. Great review. This is exactly something i've been looking for but didn't know anyone was working on. I'll pick this up.
