- First Name
- James
- Joined
- Dec 3, 2025
- Threads
- 2
- Messages
- 23
- Reaction score
- 3
- Location
- Pennsylvania
- Vehicle(s)
- 2025 Tacoma
Was wondering if anyone has installed the Auxbeam 8 Gang Switch Panel on their truck and, if so, what fuse box you tapped into and what fuse specifically? I spent a few hours trying to figure out how to get the add-a-fuse that came with the Auxbeam connected into the driver-side fuse box. I watched a few YouTube videos, but none specifically showed how to properly connect into the fuse box.
I found one video that said to use fuse F50 (INJ / Fuel Injectors). However, when I used that as my tap point for the Auxbeam, my engine shut off while the truck was running (thankfully it was parked).
From what I’ve read, a lot of people are instead using an ACC-style fuse like ECU-ACC, USB, or an ignition/accessory fuse rather than anything tied to the injectors or critical engine systems. Also seems like the add-a-fuse that comes with the auxbeam kit isnt able to fit the mini fuse from the truck.
If anyone has a fix for this that would be greatly appreciated.
Thanks.
Thanks.
