Help: "EPB Activation Stopped Incompletely" Error After Rear Caliper Replacement
vi4thgen
Vancouver Island, Canada
Toyota Tacoma, 4th Generation
Hey everyone,
Hoping to lean on the collective expertise of this group so I can get my truck back up and running ASAP. I ran into a snag while doing my rear brakes and the truck's computer is currently locking me out.
Here is the timeline of what happened:
  • I am replacing my rear pads and rotors. I already had the passenger rear pads and rotor off when I realized I forgot to put the truck into service mode.
  • I tried putting it into service mode using the manual switch sequence, but I got an error every time I tried.
  • Since I was stuck, I tried to mechanically push the caliper piston in by removing the electronic parking brake (EPB) motor and undoing the internal screw. However, when I was pushing the piston in with a clamp, there was a loud ā€œclunkā€ noise, something shifted in the piston, and brake fluid started pouring out.
  • I’ve since ordered a brand-new caliper and installed it, bled all 4 brake lines, and reinstalled the EPB motor.
The Current Issue:
I now get an "EPB Activation Stopped Incompletely" error every single time I turn the truck on (see attached ⁠image⁠).
  • I’m still unable to put the truck into service mode, so I haven't been able to do the driver's side yet.
  • When I engage and disengage the parking brake using the center console switch, I can hear the motor engage and disengage sounding normal.
  • Despite the motors working mechanically, I consistently get this error ā€œEBP Activation Stopped Incompletelyā€ and it never shows on the dash that the parking brake is successfully engaged.
I’m planning to continue working on it tonight and am wondering: is this just a hard error code I can wipe/recalibrate with a Carista OBD2 (I have the basic dongle but an active paid app subscription), or is there something else I’m missing?
Thanks in advance for the help!
2024 Tacoma Help: "EPB Activation Stopped Incompletely" Error After Rear Caliper Replacement IMG_3168
VB Taco
Virginia Beach, Virginia
I think I would try the carista to clear the code and see what that does for you.
Now I have to admit what's this talk about putting it in service mode? Looks like I needed to look in the owners manual to learn more about this.
Any vehicle that has an electronic parking brake (EPB) must be put in service mode in order to not damage the electronic actuator that engages the brake. Service mode retracts the pistons like you normally would on any other caliper.
Sounds like OP may have damaged the actuator.
VB Taco
Thanks for the lesson. Will the owners manual explain how to do this or do I need to dig deeper into the forums?
rijc99
Reset but you might need a more advanced reader than carista. Autel makes an advanced one that my friend uses at his shop. He’s come across this before and resetting the brake system seems to get rid of the message.
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
Can anyone confirm the sequence to put the EPB in service mode? There’s a couple YT vids showing pushing the manual button 3 times and there is another one showing once and hold. Maybe Disable EPB is different than Service mode.
Disabling the EPB just means that it no longer activates when you shift into Park.
You'll want to use the 3x method to enter service mode to change the brakes.
