Supertech1
Arkansas
2024 Tacoma TRD ORP
Truck looks great! I’ve got a couple questions I hope you can help with.
I waiting on TRD OR Premium, but had a chance to check out a mid-grade TRD Sport today. I was very impressed by the fit and finish of the interior. This is compared to my ‘23 Tundra TRD Pro.
One concern I have is the foot placement when sitting in the back seat. Does the Premium seat adjustment allow enough room under front seats to put your feet under seat? I don’t believe the manual adjust seats had elevation ability, but I was not able to position my feet under the front seat. Leg room was fine, but very uncomfortable when you can’t push your feet forward.
Also, does The Tacoma have the ability to learn a new set of TPMS sensors. With the Tundra, I can have two sets of wheels and go into the system settings on instrument cluster to learn the new set of TPMS sensors when changing wheels.
beninbeta
Utah
2024 Toyota Tacoma
The SR5 I drove with manual seats did have height adjustment and it was pretty surprising how far it went.
SleepyBear
2024 Tacoma, TRD Off Road 4x4
Even has tire set switching mode!
CATOY
CATOY
NorCal
I’m away for a few days so someone else will need to answer your question. I know the seat and ho up and down, not sure how much for the back. I did try to sit back there and it was very cramped, I know I can move my drivers seat up a bit to give someone more leg room on trips that aren’t too long. I’m 6’1” and I ride far back and can move up a little more than in those pictures. Going through the menus, I did see some TPS settings, didn’t dig into them any dealer. Check the manual and it should answer that question. There’s a lot of customization in the menus and you have three different screens you can setup and easily toggle through if you have the 12.3” screen.
Andy@AAV
Virginia
2010 Tacoma, 2022 Wrangler 4xe
How can the “off road” package not have a real spare tire? That’s disappointing. Thanks for the info!
CATOY
CATOY
NorCal
It’s at least somewhat close. It does say temporary on it so it’s not meant to stay on there very long. Guessing the wheel is not as wide too, hopefully we never need it. I will measure the space when I get back to see if it can accept a full size tire and wheel.
cranny
2024 Tacoma TRD Off Road Premium Hybrid
Looks like a great truck in some bad weather! Pretty sure I know the answer, but any chance yours came with sway bar disconnect? Enjoy your new truck!!
CATOY
CATOY
NorCal
No one is getting that yet from what we are seeing. Toyota is dropping it from everyone’s allocations so far.
Latoure
Nevada
Ford Ranger
Can anyone tell me the true payload capacity of the 24 TRD Off Road short bed ? I read it was 1710lbs, but the Owners Manual says only 1200lbs:(((((((
CATOY
CATOY
NorCal
That's what the stickers seem to say, there's actually another sticker that reduces that number by a couple more pounds depending on what accessories you have.
Latoure
Nevada
Ford Ranger
Which? 1710 or 1200?
