- Joined
- Feb 11, 2024
- Threads
- 2
- Messages
- 9
- Reaction score
- 34
- Location
- Long Beach, California
- Vehicle(s)
- Toyota Tacoma Off road
Nice set up!
Is your suspension the same as the SR? Will that tire setup fit the SR?
The TRD OR does not have the same suspension as the SR. I believe it sits a little higher.Is your suspension the same as the SR? Will that tire setup fit the SR?
Hi Dubz. Great looking truck. So are you saying that a 285/70R17 is rubbing/won't fit at stock ride height? I think the stock offset is +45 as well if I'm not mistaken. I was thing of going with Falken WPs in a 285/70R17 on some Method wheels with a +35 offset. I've heard conflicting thoughts as to if they will fit at stock ride height with no trimming. What are your thoughts/experience? Also, what did you do for TPMS sensors? Thanks.The Tacoma has to be lifted in order for 285's to fit.
I like the way that bed looks over the shorter bed.
I agree. It does looks better over the shorter bed.I like the way that bed looks over the shorter bed.
the OR is a little taller up front and obviously has a different rear suspension from the SR. SR/SR5 tread width is also 1cm narrower, the base wheel off-set is probably 5mm greater.Is your suspension the same as the SR? Will that tire setup fit the SR?
Something bothers me about that being taken at the psychology department...
