Need help removing D ring bolts from the bed
ridetime
Oklahoma
I need to remove the D-rings from my bed. My drill doesn’t have enough torque to do it. For you tool savvy folks what besides a more powerful drill (hand tool) can I use to drive the T-40 bit?
2024 Tacoma Need help removing D ring bolts from the bed IMG_0224
tacotaco
Michigan
2021 Jeep Gladiator
I would imagine a socket wrench and a wee bit of hand torque would break it loose pretty quickly
ridetime
ridetime
Oklahoma
Thanks, I don’t know that I have seen a socket that will fit that bit? Do you know if there is such a thing?
tacotaco
Michigan
2021 Jeep Gladiator
Ah, you will need to purchase a Torx bit socket set. Most hardware stores will have them and certain hardware stores like Ace may sell just the one you need instead of a full set
ridetime
ridetime
Oklahoma
Thank you!
Planoman
DFW, Texas
A standard 1/4 inch sized socket should word for that torx bit. Not referring to the drive size although that may be 1/4 inch also.
jsuber
juke
Jls297#40601
you can order a single torx T40 bit that fits your 3/8 or 1/2” socket wrench for less than $10 on Amazon.
CHIP702
Chip
Las Vegas
2024 Tacoma ORP, 1993 Nissan 240SX, 2022 Corolla SE, 2000 Frontier Prerunner
Autozone / Oreillys also sell Allen shaped (L) Torx wrenches, that and a cheater bar would definitely do the trick. These were pretty damn tight when I swapped out the OEM d rings for billet ones.
Bcphoto3
Bill
Oak Ridge, TN
I used an impact driver to get mine loose.. They used Blue Loctite on it and just had to break that loose..
