Jax156
Jack
Tampa
2021 tacoma trd off road
I only saw one other post with 285/65R18 BFG KO2s so I thought I'd share mine also. I can confirm no rubbing and a smooth ride.
I plan on adding the black XP wheels once they come off of backorder. They have a 45 offset and 8 inches wide vs the stock is 55 offset and 7.5 inches wide. That should give it close to 3/4 inch more poke. Which I think will be perfect for someone who doesn't want to go too far out.
Flyfish007
NJ
2024 TRD Sport
My Sport is being built and Im getting the TRD wheels..been looking at the same tires you have. How is the ride?
Jax156
Jax156
Jack
Tampa
Congrats on your build, my buying process was a nightmare so hopefully yours goes a little more smooth.
Ride is slightly more bumpy on unsmooth roads, but not enough that the average person would even recognize. The steering actually feels better. Almost like the steering wheel tightened up a bit. So overall looks better and drives better IMO.
Flyfish007
NJ
2024 TRD Sport
Excellent Thats what I was hoping you would say! I wish there was a way to try tires before buying lol.
My buying process...I requested the trd sport with premium package and the TRD Wheels...The dealer thought I said "I want every single port option". I got the spec sheet and almost fell over. Luckily it was an easy change so hopefully theres no more drama lol.
Jax156
Jax156
Jack
Tampa
I promise overall you'll be happy with the KO2s. KO3s just released but theres still some unknowns.
Toyota clumps a lot of items together in their packages and will say "that's the way it comes" but if you really spend the time researching you could save a ton by buying those options individually. For instance I was quoted 1300 for predator side steps when I could buy them for 600 and its 8 bolts. Most folks just say screw it and throw "x" package on there and be done with it.
Ron
Samsara
I like that look for offset / poke but the black wheels do look better - especially on silver
2024 TRD Sport-Bronze oxide.
One thing to watch for with the KO's.........if you travel on rocky roads, the tires get rocks stuck in them and then fling them out at higher speeds and can chip your paint. 3:35 mark in THIS video.
Goriders
2024 Tacoma Sport Plus
That’s essentially what I’m going to do but on 275/65 R18 tires. Can’t find the upgraded TRD rims yet though. Might leave the tires on the stock Sport 18” rims until next summer. I’m going to use the stock rims for winter tires.
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
Hey Dave.
I just ditched my Michelin Primacy tires that came with my sport. Tirerack gave them a 5.5 for winter driving, which around Calgary for us isn't brilliant. I kept my stock rims and went with an all-weather. I think the KO is also winter rated, but something to consider before the end of the year. ?
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
There's a comparison betweek KO2s and KO3s here: https://www.tacoma4g.com/forum/thre...ide-by-side-look-and-technical-analysis.4467/
Tanrmt09
Tabr
96 Toyota 4runner
Man idk why but a 285 just doesn't look as wide as I was hoping on these trucks. Maybe it's the stock wheel width. Other then width it looks good filling up the wheel well. Hopefully my 18x9 methods will make the 285 look a bit wider. I think a 305 will be overkill
Jax156
Jax156
Jack
Tampa
45-35 offset will make it look wider. It's just tucked to tight right now
