Anyone else tried 255/80r17?
Omega351
West Georgia
Silverado 3500 Tacoma SR5 4x4
Stock SR5 4x4, has very little perceivable rake, I had this tire planned a ways before I got the truck, I’m surprised as popular as it was on the much narrower gen3 I’m the first I’ve seen to do this size on a gen4.
2024 Tacoma Anyone else tried 255/80r17? IMG_3201
2024 Tacoma Anyone else tried 255/80r17? IMG_3203
Romer
Ken
Centennial, CO
I was looking at this tire as a matching spare that doesn't stick to far out the bottom. Matching means 5 identical tires.
The spare tire is 9.6" and there is another thread where someone put a 285/70 R 17 on as a spare. It works but sticks down farther as it is 11.2" wide
Picture in the link
https://www.tacoma4g.com/forum/threads/285-70-17-tires-with-or-without-lift.2410/page-2#post-72468
I don't like off-roading without a matched spare so was thinking this would fit better in the spare spot. There is a cross member that prevents the tire from going higher against the bed.
TrustButVerify
central
Several
BTW, that also fits in the spare tire spot.
Did you keep the stock steel spare tire rim? Trying to figure out what size tire will reasonably fit on the spare. Having a stock spare that's almost 2" smaller diameter is a total cheapout on Toyota's part. The 245/70R17 is hardly a "full size." It's more like a smedium size.
Romer
Ken
Centennial, CO
I bought a TRD Off road rim that matched the other 4 for the new spare. The old one is in my garage, not sure what I am going to do with it. The spare is is the same size as the 4 I just put on 255 80 r17's Toyo AT3's. That is 33.1" tall.
TrustButVerify
central
Several
Do you recall the part number for the oem trd OR rim/wheel? I couldn't figure it out from the Toyota website, and the rim didn't have anything on it suggesting it's number. I like the idea of a fifth matches wheel/tire.
I did find that the steel spare wheel is a 7" wide wheel, so that should make finding a tire easy.
Romer
Ken
Centennial, CO
2024 tacoma 17” FACTORY OEM RIMS 95893 A
hemlockz
‘24 TRD Offroad 6MT
Any idea what the weight is compared to the stock trail terrains (34 lbs I believe?)
Edit: 53 lbs according to google, to answer my question, so additional 19 per
