2024 Tacoma D Ring Install
FloridaTaco
Liv
2024 Tacoma SR5
I just received these as a gift for my birthday. I’m looking under my 2024 Tacoma and don’t see any attachment points. Is there anything I need to add to get these on properly? TIA
2024 Tacoma 2024 Tacoma D Ring Install IMG_2762
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Zanez
Zane
Cali
I had the same issue. I want those type of recovery shackles but like soupy1234 said you have to have the right setup on the frame. I haven't seen anything that would work for those yet.
Duck Amuck
If you don't want to spend a bunch of money on recovery points for now, you can get a hitch receiver recovery point. This one is just the first I found on Google, there are lots of others. Many will already include the D-rings so you might have to hunt for one that doesn't.
Zanez
Zane
Cali
I went with the Rough Country kit and they are solid for the price. They offer front and rear.
Just looked at their site. Down towards the bottom they say It doesn't fit TRD off-road
StreeTaco
2024 Tacoma TrailHunter
Hopefully they meant TRD Pro.. OR is the most common trim
Zanez
Zane
Cali
FREE SHIPPING
$149.95
Add to Cart
2024 Tacoma 2024 Tacoma D Ring Install ag4a2539
2024 Tacoma 2024 Tacoma D Ring Install ag4a2569
2024 Tacoma 2024 Tacoma D Ring Install ag4a2604
2024 Tacoma 2024 Tacoma D Ring Install ag4a4703_1
2024 Tacoma 2024 Tacoma D Ring Install 2024_tacoma_front_d-ring_mounts_-_73126
2024 Tacoma 2024 Tacoma D Ring Install dsc00618_1
2024 Tacoma 2024 Tacoma D Ring Install dsc00623_1
2024 Tacoma 2024 Tacoma D Ring Install fc3a0136
2024 Tacoma 2024 Tacoma D Ring Install fc3a0137
2024 Tacoma 2024 Tacoma D Ring Install fc3a0139_2
2024 Tacoma 2024 Tacoma D Ring Install fc3a0398
2024 Tacoma 2024 Tacoma D Ring Install fc3a0798_1
2024 Tacoma 2024 Tacoma D Ring Install 0
In Stock • Ships FREE
SKU:
73126
Brand:
Rough Country
Lowest Price Guarantee
Products Similar to this Item
Rear Shackle Kit
D-Ring Combo | Toyota Tacoma 2WD/4WD (2024)
8 reviews
2024 Tacoma 2024 Tacoma D Ring Install ag4a2534
$129.95
In stock
Hidden Winch Mount
Toyota Tacoma 4WD (2024)
Be first to review
2024 Tacoma 2024 Tacoma D Ring Install 2024_tacoma_hidden_winch_mount_-_72011_1
Starting at
$649.95
Configurable
Winch Recovery Kit
Synthetic Cable Winches
Be first to review
2024 Tacoma 2024 Tacoma D Ring Install lipz0thh
$259.95
In stock
3.5 Inch Lift Kit
N3 | Toyota Tacoma 4WD (2024)
1 reviews
2024 Tacoma 2024 Tacoma D Ring Install 2024_tacoma_3.5in_lift_-_75630
$799.95
In stock
LED Ditch Light Kit
Toyota Tacoma (2024)
2 reviews
2024 Tacoma 2024 Tacoma D Ring Install ag4a8711_1
Starting at
$89.95
Configurable
Hood Struts
Hydraulic | Toyota Tacoma 2WD/4WD (2024)
8 reviews
2024 Tacoma 2024 Tacoma D Ring Install ag4a7519
$89.95
In stock
Works Well Together
Customers Frequently Bought Together
2024 Tacoma 2024 Tacoma D Ring Install 3978bfb8524b2b2137861be68123658%2Fa%2Fg%2Fag4a2539
Front Shackle Kit
$149.95
Current Item
2024 Tacoma 2024 Tacoma D Ring Install com%2Fmedia%2Fcatalog%2Fproduct%2Fa%2Fg%2Fag4a2534
Rear Shackle Kit
$129.95
Add to Cart
2024 Tacoma 2024 Tacoma D Ring Install Fproduct%2Fd%2F-%2Fd-ring_isolator_black_-_rs103-2
D Ring Shackle Isolators [Pair]
$7.95
Add to Cart
Total:
$287.85
Add All Items to Cart
Customers Also Bought
Steel Wheel
Black | 17x9 | 6x5.5 | 4.25 Bore | -12
84 reviews
2024 Tacoma 2024 Tacoma D Ring Install black_steel_wheel_-_open_cap_3
$84.95
In stock
LED Rock Light Kit
4 Piece Set
128 reviews
2024 Tacoma 2024 Tacoma D Ring Install rc_rock_light_kit_-_70980
$64.95
In stock
8 Gang Switch Panel
RGB Backlit Buttons | Multifunction Modes
101 reviews
2024 Tacoma 2024 Tacoma D Ring Install 8-gang-multiple-light-controller_70970a-install8
$199.95
In stock
Universal Bed Rail Flag Pole Holder
36 reviews
2024 Tacoma 2024 Tacoma D Ring Install universal_bed_rail_flag_pole_holder_-_117501
Starting at
$29.95
Configurable
40 L Portable Refrigerator/Freezer
12 Volt/AC 110
109 reviews
2024 Tacoma 2024 Tacoma D Ring Install 12-volt_cooler_contents_-_99020_1
$349.95
Folding Mechanics Mat
1.25" Thick EVA Foam | 22 x 55 inches
46 reviews
2024 Tacoma 2024 Tacoma D Ring Install utility-6-fold-mat_bas
$59.95
In stock
Features
Equip your fourth-generation Tacoma with Rough Country's front D-ring Shackle Kit! This isn't your average add-on—it's a game-changer for your truck's off-road capabilities.
See Full Description
  • Easy, bolt-on install using factory mounts under frame with no cutting.
  • Center mounts made from 1/2" Steel.
  • Mounting plates constructed using 1/4" Steel.
  • Wrapped in 7ga steel with laser cut RC logo.
  • Laminated design for added strength.
  • Accommodates shackles or D-rings with 7/8" pin diameter.
  • Mounts to frame horns behind front bumper for added support.
  • Durable, black powder coat finish.
Fitment Notes
  • Does NOT fit TRD Off-Road models.
  • Designed for recovery purposes ONLY.
  • Designed to accommodate shackles with 7/8in size threaded pins.
rideradk
Glenville NY
2024 TRD Offroad
Rough country makes a rear shackle kit that I installed. I upgraded the shackles it came with and went with something like yours. Their front shackle kit does not work with the OR trim because if the front cross member. I had to return them.
soupy1234
Show Low AZ
Fronts don't fit Off-Road.
Rears do not have that restriction.
Not sure I like the way they mount by using brackets around the bumper frame.
If anyone has actually seen the rear set, how thick is the metal?
Edit: never mind, I see it says 1/4 inch.
grizzlyoutlaw
MTN WEST
TACOMA
2024 Tacoma 2024 Tacoma D Ring Install 20240707_130423
