How much rake does your stock suspension Tacoma have?
Powhunter
Alberta
I’m trying to determine if different models might be higher in the front. Post what model you have and what your rake is (difference in height between front fender to ground and rear fender to ground)
I have a TRD OR on stock suspension and my rake is 2.0 inches.
Richm
Richard
VT
2024 TRD Off Road, 2020 RAV4 XLE
2024 TRD OffRoad, stock suspension
Going by wheel well opening, i have 37" in the rear and 35 1/2" in front
If you measure the lip on the bottom of the rocker panel, i have 16 1/2" rear measurement and 15 15/16" in the front.
So if i did a 1 1/2" front lift, it would even out the wheel well openings but in my opinion it makes it look nose high if you go by body lines and bottom of rockers/cab
Deleted User 412290
Just discovered this first hand with the bilstein 5100s. Went with 1.4" which measured perfectly level at the wheel wells, but to my eye it looked a bit nose high. Put a .5" spacer in the rear and going by rocker/cab measurements that made the truck perfectly level.
I had originally thought I had 2" of rake because I was measuring by the wheel well.
Ultimately for me I'm going down to 1" in the front and keeping a .5" spacer in the rear to keep a little bit of rake.
gmalkmus
SW Missouri
2025 Tacoma TRD Offroad 6MT, 2015 Mustang GT 6MT
With stock suspension, there really isn’t too bad of a rake. Saving for a kit kit so I don’t end up squatting the truck every time I put something in the bed with a leveling kit. Been there done that in my last truck.
2024 Tacoma How much rake does your stock suspension Tacoma have? IMG_6706
