đźš— Tacoma Owners: What Makes the Perfect Car Vacuum Cleaner? (Quick Survey)
What are your Top priorities when buying a car vacuum?
  • Total voters
TreadAuto
www.amazon.com
Jeep Gladiator
Hey everyone,
We're doing some research on car vacuums and would love to hear from real truck owners. Whether you use a handheld vacuum, shop vac, or cordless model, your feedback is greatly appreciated.
As a thank-you for your valuable feedback, we'll randomly select one participant to receive a set of Michelin Floor Mats.
If you were designing the perfect Wireless Car Vacuum for your truck, what would you improve first?
When shopping for a car vacuum, what features matter most to you?
1. Suction power, is 7,500–24,000 Pa of suction enough?
2. Battery life, is 15–30 minutes of runtime enough?
3. Filtration system, any idea on the difference between: Cyclonic, HEPA, Cartridge, Foam, Mesh, etc.?
4. Charging Time,
would a 3–4 hour charging time be acceptable?
5. Price, would 50$-100$ be acceptable?
6. Portability
7. Accessories
8. Brand
9. Other
What's your biggest frustration with your current car vacuum?
Thank you for sharing your experience! Your insights will help us better understand what vehicle owners are looking for in a car vacuum cleaner and support us in developing products that better meet their needs.
*You could check out our Michelin products on Amazon or our official website ⬇
Ragin Rabbi
Matt
2024 Tacoma Off Road Hybrid
Attachment that keeps strong suction, but allows me to get into crevices and such (around seats) easier!
BTAO
Andy
NE
2025 Trailhunter
No handheld has ever been strong enough for the floors. Mine is a rigid shop vac with the car detail hose kit. It's okay.
What I'd like to see are truly better attachments for brushing up dirt from the floor, delicate but long enough to clean the dash up to the window, one with soft bristle skirt for vents and shift boots, and some sort of sling you can wear to keep the damn hose from dragging across the door sill paint.
And another big one, add a feature to blow air with a nozzle to get stuff out of cracks you can't get otherwise. It's my only pro tip. When I go in to detail, I hit everything with the air compressor first, let it settle, then vacuum it all up. That would be game changing
thewraith
DC metro
rx7 fd w/2j swap, '65 stang, '25 camry, '25 ev9 gt
I've been through half a dozen "portable" car vacs at least. From cheap $80 models to expensive $550 models. Nothing beats a good old shop vac with a long hose. If you don't have room for that, get an attachment for your home dyson or buy the dewalt 20v, a hose kit, and an aftermarket higher mah battery, which seems to work great for the price.
2024 Tacoma đźš— Tacoma Owners: What Makes the Perfect Car Vacuum Cleaner? (Quick Survey) DCV501HB1__797NU5_v1?$adapimg$&hei=536&wid=536
rdalemercer
Dale
Nojiri178~~
2026 Toyota Tacoma
Hey everyone,
4. Charging Time,
6. Portability
7. Accessories
8. Brand
9. Other
I prefer a wall mounted WET/DRY vacuum. Wireless are not only too weak, but don't last as long.
I normally use a vacuum at home, so a wall mounted, high suction unit with the proper attachments to get into all crevices while also broad applications for general suction.
Long hose that is proudly protected to not scratch, scuff or damage the paint is necessary.
OminousSkitter
Alaska
Mountain Bike
A home vacuum and a car vacuum have different needs. Most of the poll sounds like a wishlist for a home vacuum but is not needed for a car vacuum.
Longer battery/faster charging? I've never understood the appeal of a wireless vacuum for a car. You don't need the vacuum with you on roadtrips or when you're away from your house or shop, so portability isn't an issue. And if you truly need a vacuum on a road trip, a couple bucks goes a long way at a carwash's coin-operated vacuum.
Compact size? Size/space can be an appeal for storage—especially for renters—but is way less-important than power. A long hose is way more maneuverable for vacuuming than a handheld every will be.
Better filtration? Most people vacuum a car outside. Filtration mostly matters inside that you're not just shooting dust all over what you just vacuumed. Better filtration is a solution looking for a problem (or really just marketing to increase the price tag).
I've always used a shop vac, but any strong vacuum with a long hose works great if it has the right attachments to get into crevices, under the front seat near the rails, etc. Bonus points if it has an attachment that works well on fur, as many people let their dog(s) ride in their trucks.
MJB4450
2025 SR5
Strong suction, long battery life, able to reach those nooks and crannies around the seats, cleanable filter. If it takes a while to recharge, that's OK since it's not like I'll need it every 10 minutes. Who cares about the brand name stamped on it so long as it works well. Needs to be durable and not crap out after 90 days. Size not very important as long as it's a handheld device. Be nice if it came with, or sold a separate tiny competent vac with attached brush for the A/C vents and dash crevices. I've been using a Black and Decker lithium 20 volt for many years now. Still works well but could be stronger suction and the nozzle doesn't fit tight areas. But it recharges very fast.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I’d like a powerful vacuum that reaches as many surfaces as possible. Running off a choice of power sources (120v AC or 12v DC) would be nice whether parked at home or on a trip. Then I could clean our little trailer as well as the truck. Don’t want the expense, weight, and short life of a battery pack. There are plenty of plug-in power sources available these days.
My current way to vacuum my truck is with a huge Ridgid HEPA wet/dry machine. It’s nice that it’s on wheels but is still a bear to manage even with its long hose. I have to use a 25’ extension cord. Takes me longer to set up and put away than to vacuum the cabin and occasionally the bed.
lauren01
Lauren
Ventura, CA USA
I second the blower feature. Pro detailer tip.
TreadAuto
TreadAuto
www.amazon.com
Jeep Gladiator
This is a really strong workflow idea. Especially the air blow + vacuum combo.
Feels like the gap is in better tool integration: agitation, reach, and debris control all in one system.
If you had to pick one to prioritize first, would it be the air blow function or the brush system?
TreadAuto
TreadAuto
www.amazon.com
Jeep Gladiator
That makes sense. Once suction and consistency matter more than mobility, wall-mounted starts to win out.
Curious how you’d see the hose situation working in practice, more like a fixed setup you pull from the wall, or something you still move around the vehicle as you clean different areas?
TreadAuto
TreadAuto
www.amazon.com
Jeep Gladiator
Yeah, this actually makes a lot of sense. What you’re really optimizing for is coverage + uptime + minimal setup friction, not portability.
That “setup/tear-down takes longer than the cleaning” problem with the Ridgid is probably the real pain point here.
Curious if there was a system that stayed permanently mounted (garage or trailer) but could also tap into 12V in a pinch on the road, would that meaningfully improve things for you, or is AC power always going to be the preferred mode when available?
lauren01
Lauren
Ventura, CA USA
I’m assuming AC power is able to provide the strongest suction/blowing and cooling for the motor’s fan and more stable voltage than 12v. My truck and tiny trailer have both AC and 12v as well as we have power stations with both.
My preference would be a portable unit, not permanently mounted. Spaces are small in Tacomas and our trailer. The trailer is basically a queen sized mattress 80” x 60” plus about 24” of space behind the 80”. Height inside is 48” at its peak.
To be able to use a vac/blower inside and outside truck and trailer it needs to be portable. A suction mount option could work. The vac power cord could be kept on a retractable reel. After exterior washing either vehicle, it would be fantastic to be able to blow the water out of cracks without the noise of a big compressor. Campers and detailers would love that.
BTAO
Andy
NE
2025 Trailhunter
Cool beans. I don't have pets, so the air blow -> vac is the way to go for me. I've detailed a few of my fam/friends' vehicles in the past, and if they had too much fur to deal with, I'd have to do a rough pass to break up the fur, then blast it, then vac. Either way, I like having the stiff, shorter 3/8" bristle wand for the tough stuff, then a longer, softer one for the trim and dash. The air blast takes care of cleaning pockets, like cup holders, door pockets, etc.
rdalemercer
Dale
Nojiri178~~
2026 Toyota Tacoma
Yes. Fixed to the wall with a roll-up or retractable setup.
Long hose - 30' without losing suction!
The hose needs to protect the surface that it rubs against.
Suck & Blow would be awesome, however, I'm not certain how that works without blowing the dust back out?
I have a separate handheld blower that I use after my wash to de-water the crevices, grill and wheels.
