izzy
Bay Area
Now I can't say "never driven offroad" or "never wheeled" ? my poor resale value.. anyways
Didn't air down, used 4Lo after the trans temp started to go up once we hit the dirt, which didn't take long. Only did a few thousand feet of dirt, ran out of time to get to the summit. Did the orange line on the OnX map on Maple Spring Road to the first hairpin.
Overall very capable on stock all seasons. I'll be shopping for Trail Terrains in close to the OEM tire size, (245/75/17).
Ran across a lot of friendly trail peeps, lots of 3Gs, motorcycles, one Bronco, and some guys in a Honda Accord LOL
The truck is going to see more dirt in the future, so I've got some aluminum CBI plates on the way (front and rear). Went for aluminum because I mostly wanted the plates as insurance for a rock I didn't see and not so much for sliding on. I can't see myself doing trails much more extreme than this.
2024 Tacoma Popped the SRs offroad cherry today 1000002381
2024 Tacoma Popped the SRs offroad cherry today 1000002401
2024 Tacoma Popped the SRs offroad cherry today 1000002383
2024 Tacoma Popped the SRs offroad cherry today 1000002406
stuckinsocal
24 TRD OR 6MT
I wonder what is causing all of the temp warnings on the automatics? Is it going off at a lower temp than other vehicles, is it because of the extra torque, is it the programing of the transmission (not locking up enough). Mines is a 6MT so not affected by this and going in 4LO fixes the issue but this is not the only report I've heard of this.
On a more positive note, glad you had fun OP!
izzy
izzy
Bay Area
I really don't know actually. Most of the climb was 10-15mph on the paved section, trans temps were higher than street driving but still ok. What I noticed when we got onto the dirt trail is the RPMs were quite low, I was crawling up at about 5-10mph. Which checks out, the torque on the T24A-FTS is around 1600-2000RPM. I believe in first gear the trans should be locked up around 5mph, it's pretty short but maybe you're right here.
I think what's going on is, when you shift to 4Lo you're raising the RPMs and thus pumping more coolant through the radiator.
Another thing is the SR5+ engines have a oil to coolant oil cooler, which is really more of a oil temp regulator to be honest. What that oil cooler is also doing though is raising the thermal load of the radiator. So it's possible the high output variant might overheat the trans sooner than the 228hp motor possibly because of the oil cooler is dumping that heat into the radiator.
The trans temp stopped climbing in 4Lo, around 3/4 the way up, pretty close to the red bar, and then when I idled the truck at the hairpin it dropped back to normal quite fast.
All speculation on the temp stuff, maybe Toyota shouldn't have given us temp gauges LOL
Edit: and to be fair, the trans didn't overheat, and it might have not even in 4Hi, so maybe my switching to 4Lo was premature? Not really sure. All I know is the gauge went up when I put it in 4Hi ?
stuckinsocal
24 TRD OR 6MT
I agree it may be a combination of all those factors. If it cooled really quickly it could just be they are being extra proactive in regards to transmission temps as well. Maybe "manual mode" and keep it in a lower gear would have helped as well (though your motor might start getting a bit hot instead!). On another note I need to try some of the trails down there; I've gone to some near the Cajon Pass and Santa Clarita and I always want to explore new places when I have the time.
I'm not trying to be a forum troll, so I don't take it that way. Why four low? It doesn't look steep.
izzy
izzy
Bay Area
Yeah I had it in 2nd in manual mode for a bit then 1st actually, RPMs were still pretty low in first for 5-7mph. Either way we'll see about the trans temp stuff, next time the truck is offroad I'll keep an eye on it again for sure.
Yeah definitely do, I wish I had more time to at least get to the turnout at 4000ft, which was kind of around the corner. Very cool trail and beautiful views. Called a head to make sure it was open, fire season coming so I wasn't sure.
izzy
izzy
Bay Area
There was a section behind the turn that was pretty steep.
Stuff like that never really translates in photos unless you get a telephoto lens and walk a few hundred feet away lol or see it in person.
Keep in mind we are also 400 miles from home on a trip so I really didn't want to tear up the all seasons on a sharp rock or something. I was going slower than I needed to for sure.
4Hi seemed ok, the tires were gripping but the RPMs were low, truck seemed happier in 4Lo for 5-7mph.
The orange square I highlighted is where a pretty steep 100ft climb is, very rutted too. The locals told me it used to be worse lol The photo from the dash is after that section, where it flattens a bit.
2024 Tacoma Popped the SRs offroad cherry today 1000002394
2024 Tacoma Popped the SRs offroad cherry today Screenshot_2025-06-21-09-27-30-311_onxmaps.offroad-edit
Brent@ANParts
Brent
www.autonationparts.com
Ford Bronco
I usually like to reserve 4L for especially tough stuff, or when 4H is really struggling. I'm always worried I'll leave it in 4L and forget.
But nicely done for a first trip! Once you get your first little scratch on some trim the off-road anxiety goes away.
izzy
izzy
Bay Area
Yeah most of the trail I was in 2WD actually, aside from the first little climb on dirt. Then I was back in 4Hi when it levelled off but we reached the first hairpin by then and ran out of time.
Didn't really need to use 4Lo really but I was curious to see if it would lower the trans temp (seemed to? didn't use it for enough time). By the time the trail levelled off the trans temp would have come down anyways so my experiment was moot probably. Also didn't want to spin the all seasons, they seem a little thin haha
Yeah true! I washed the truck after we got back and I didn't see any bad pinstripes but I'm sure it picked some up. It's a truck ??
Edit: Also I will say OnX said the trail was difficultly "2" / Green Dot, which is probably true but there were some pretty technical sections (where you really wanted to pick your line) and fist sized loose rocks that you probably don't wanna run over. Definitely not a flat desert trail lol
izzy
izzy
Bay Area
Solved the tire durability issue ?
New take-off TRD OR wheel set was cheaper than new tires on their own LOL
2024 Tacoma Popped the SRs offroad cherry today IMG_20250624_174512
2024 Tacoma Popped the SRs offroad cherry today IMG_20250624_190102_1
JakeJoeBob
Jake
24' TRD Offroad
My gut says it's an AINSIN QC issue more than a design issue. Would explain why some overheat and others don't. Thats complete speculation though lol.
izzy
izzy
Bay Area
If thats the case... as long as I get a free updated trans before the extended warranty runs out I'm happy LOL
To be fair though, I bet it wouldn't have overheated even if we went all the way to the top of the trail. Empty bed and 80F ambient? Seems like the guys that are truly overheating are towing and loaded.
The trans temp gauge moved up for sure, but that doesn't mean that much. The oil temp was dead center, unlike when I was on the Grapevine on the way to LA, but coolant tempt didn't move at all then so that's moot. Oil temp will always rise when your turbo is spooled for longer than a few minutes.
JakeJoeBob
Jake
24' TRD Offroad
I have had my trucked loaded down in 4 hi from big bear dropping into the desert and did not see temps move. Done that plenty of times. Same thing on highways out loaded down out to joshua tree. I just have never seen the issue manifest in any condition.
izzy
izzy
Bay Area
Well I was in 4Hi downhill and the temps obviously went down. Seems like 4Hi + steep grades uphill is what raised the temps. In 2Hi the trans temp doesn't move, up highway grades or not.
JakeJoeBob
Jake
24' TRD Offroad
I should have clarified, I have done that trail both ways (2N02). In 4 Hi, both coming up from Pioneertown and going down with the truck loaded . It's a good time :)
