bsquaredMTB
Ben
El Paso, TX
GREAT PICS!!!! What is your current setup? Are you running stock or do you need a lift to do top of the world?
BTAC16
BTAC16
Rob
Loteks16!
I’m running 35 11.50’s with 2” front and rear lift. You could probably make it but be prepared to drag on the frame. I definitely wouldn’t do it without armor
bsquaredMTB
Ben
El Paso, TX
Nice. I figured you needed some lift so I'm glad you confirmed that! Thanks!
BTAC16
BTAC16
Rob
Loteks16!
wait.. How did you fit the gazelle inside the smart cap? assuming you had to store it at an angle.
I have the 3 person tent it’s only like 4ft long. I think the 4 person is longer
2024 Tacoma Moab trip/ Top Of The World IMG_7918
Rising Sun
Tom
North Georgia USA
2025 Toyota Tacoma Trailhunter
Smart to put your spare in the bed for that kind of work. Looks like a blast. Did you use any particular method or mount to keep the tire vertical or just straps ?
stuckinsocal
24 TRD OR 6MT
How are you liking the Wildpeak RT01s? Are they loud? Debating between them and KO3s.
BTAC16
BTAC16
Rob
Loteks16!
Just straps, I’d like to get a mount but can’t justify the cost
BTAC16
BTAC16
Rob
Loteks16!
I only have a couple thousand miles on them but they are quiet so far. Hopefully that doesn’t change with wear. I was also looking at the ko3 there’s a 35/11.50 that should be available soon but I didn’t want to wait.
BTAC16
BTAC16
Rob
Loteks16!
How was it? We'll be that way in October.
This trail is slow and rough but the view is definitely worth it. You definitely have to take proper lines and watch tire placement. The last half mile or so was the most difficult. October should be a great time to go, the heat is brutal right now. If you haven’t been to Moab hit fins & things also
