marie_arb
Marie
Seattle, WA
Toyota
So you've been debating whether you actually need a topper or cap for your 4th Gen. It makes sense why. Your truck bed is one of the most useful parts of the Tacoma (we know for some of you, that's the whole reason you picked a Tacoma over a 4Runner), but it's also one of the most exposed. At some point, the question stops being whether you should cover it, and turns into what you should cover it with.
And that's usually where people get stuck. Maybe it's the price tag, maybe you can't quite justify the purchase yet, or maybe you've just got a dozen tabs open and can't decide which one actually makes sense for your build.
That's what we're getting into here: hard cap vs. soft topper, a quick intro on the ARB Ascent Truck Cap, and whether it's right for you.
Why Cover Your Bed At All?
Nobody loves pulling into a gas station or a trailhead lot with gear sitting out in the open for everyone to see. Beyond just keeping prying eyes off your stuff, a cover keeps rain, dust, and UV off your gear and actually gives you room to load things up instead of stacking everything flat. A hard cap takes that a step further, since the roof itself becomes a stable spot to mount a rack, lighting, or anything else you'd rather bolt down than just toss in the bed.
So yeah, you need something over that bed. The real question is hard cap or soft topper. Let me walk you through the differences.
Hard Cap vs. Soft Topper: What's the Real Difference
A soft topper isn't the tonneau cover you might be picturing. It's a canvas-sided shell that mounts to your bed rails on a folding frame, and a lot of them actually give you standing height inside once they're popped up. They're light, they pack down small, and they're an easy way to get more usable space without adding much weight to the truck. The catch is that canvas is still canvas. Zippers and fabric walls don't lock, they don't fully keep out dust or bugs or bad guys, and they're not going anywhere near a roof rack.
A hard cap, on the other hand, is more like a second cabin bolted onto your bed than a cover. It's rated to actually hold weight, it locks, and there's enough height inside to organize your gear. You don't have to worry about the canvas losing its shape or ripping. And most options come with windows, lighting, and ventilation already built in.
Here's the trade-off in plain terms: a hard cap costs more and adds weight, but you're trading a soft shell for a locked, weatherproof, load-rated box.
So for everyone running one or the other right now, what made you pick your setup?
Meet the Ascent Truck Cap
Most caps on the market are built to a generic bed size and then shimmed, stretched, or bolted on until they fit. Our Ascent Truck Cap was engineered around the 4th Gen 5ft bed specifically, so the fit is clean from the factory line up front to the tailgate. But we’ll let the specs and features do the talking:
  • 275lbs dynamic weight rating and a static weight rating of 770lbs
  • Electronic central locking working simultaneously with the vehicle’s doors via the vehicle’s OEM key fob.
  • A double-curved rear glass door and side windows with frameless, tinted safety glass
  • Lift-up windows to allow for easier access to the back
  • A clear, lift-up front window providing unobstructed rear vision
  • A slimline, high-flow Truck Cap vent to reduce dust
  • Electronic locking system providing easy, one-handed operation to lift or close the glass.
  • LED interior lighting controlled via a three-way switch.
Our goal with the Ascent Truck Cap was to make the bed as usable, secure, and low-hassle as possible. Want to learn more about it? Check out our blog post.
How It Stacks Up Against Other Hard Caps
Most hard caps for the 4th Gen check the same basic boxes: windows, some kind of locking, rack compatibility. Where the Ascent really separates itself is in the details most people don't think to ask about until they're living with the cap day-to-day.
A lot of caps still hand you a separate key or a basic mechanical latch, which means one more thing to remember. The Ascent's electronic latching syncs straight into your factory key fob, so it locks and unlocks in step with your doors.
Also, many caps feature vents, but the Ascent's slimline, high-flow vent is positioned to face the front of the vehicle, so airflow pressurizes the canopy interior and limits dust from working its way in through the rear door or tailgate. The low-profile design is also built to clear roof racks, so you're not choosing between ventilation and rack space.
Most hard caps on the market are stainless steel or aluminum, usually finished in a black powder coat. That’s fine and all, but we took it one step further and made ours out of ABS thermoplastic shell finished in OEM-matched paint across 10 factory colors, perfect for those who want a cap that actually matches their truck.
Add-Ons Worth Looking At
And for those that want more, we've got add-ons.
Need a rack? Get the BASE Rack, a modular rack built on a dovetail mount that lets you add, remove, and reposition gear without tearing apart the rest of your load every time you need something. No cross bars needed, and you can run wiring internally for lighting or other accessories.
To run a rack, you will need the Internal Frame and Tub Brace. It ties into the bed frame and bumps the Ascent's rating up to 240 lbs dynamic and up to 880 lbs static, stiffening the bed and taking the stress off the composite tub.
Let's Talk Price
It's a fair question to ask what that $4,495.95 number actually buys you, and the Tacoma itself is part of the answer. Did you know that on average, owners tend to hang onto these trucks for around 9 to 11 years (thanks to how well they hold up mechanically and how little they depreciate)? Spread the Ascent's price over that kind of ownership, and it works out to around $35 to $40 a month for a cap that locks with your key fob, holds up to 770 lbs static, seals out dust and UV with real glass, and already has the mounting points for a frame brace and roof rack when you're ready.
Buy something cheaper now that can't do those things, and you'll probably end up buying this cap anyway.
Ready to Stop Debating and Just Get One?
If you want your bed to function as a secure, weatherproof storage instead of just a rain shield, the Ascent is built to be the last cap you buy.
Got questions about fitment, the add-ons, or whether this makes sense for your build? Drop them below; happy to help.
Toy-truck
Houston, TX
@marie_arb I tried ordering the Ascent Truck Cap in Bronze Oxide paint color but it stated that "The selected product combination is currently unavailable." Do you know when Bronze Oxide paint color will be available?
Will721
Quad Cities
I would argue that a good, properly installed soft top is weather tight. Plus, thieves don't give a damn about a lock and just bust out a window without even setting off an alarm and when they do its gonna be expensive. Load bearing and a sleaker look are your real advertising points here. That's all it comes down to. A cleaner look and load bearing capability vs overall price point and ease of removal.
Personally I went soft top. Why? Because while it was cheaper cost was only an added bonus. If you use your truck as a truck, you'll find quite a few loads don't fit under a topper of any design. At that point its either muscle a heavy bulky hard top off or get a trailer.
However, Im sure your top is great. Ive never seen an ARB product that wasn't. It definitely looks good and arguably would look better than my soft top. It is a better solution for those who use their truck more like an SUV or mobile camper.
Regius
Reg
New York
2024 Tacoma TRD Offroad, non-hybrid, 5.5 bed, silver
One main reason for me not to have a cap is that it'd need more athletic skill from me to hop on the bed, I will keep my head down in order not to bang it on the ceiling of the cap. Not to mention I will no longer able to stand in my bed. Otherwise I love the extra space and look of some of the hard caps.
marie_arb
marie_arb
Marie
Seattle, WA
Toyota
Hello!
I do not have a current timeline as to when it will be available. I would recommend, if you haven't done so already, to sign up for the notifications on the product listing, and we'll email you when they are back in stock.
Thanks,
Marie
marie_arb
marie_arb
Marie
Seattle, WA
Toyota
Hey Will, thanks for sharing your thoughts and thank you for the praise!
I think nothing will stop someone who's truly committed to getting in. But our Ascent cap does make it a bit harder than a soft topper, where a fabric wall is an easy target, compared to 5mm safety glass and a lock on our cap. It's not bulletproof, but it's enough of a hassle that most people move on to the next truck.
And you're right, a soft topper is easier to pull off when you need the extra space. Our cap is built more for those keeping gear or tools in the truck bed and need a secure space to put everything. So we don't really see people pulling it off much, and on the rare occasion someone does, it's not hard to reinstall!
marie_arb
marie_arb
Marie
Seattle, WA
Toyota
Hello,
It's true, once you add a cap, it does make getting into the bed a bit more difficult, but on the bright side, everything that's in bed will be protected!
joebangle
rob
east coast
25 trd offroad
I noticed the arb cap overlaps the bed side moulding. We have bed scene lighting and do not see an option for this when ordering the cap. When will we see arb offer a bedscene lighting comparable cap. Spending north of 4k on a cap I certainly don't want to have to modify it...
