NHTaco
Seth
New Hampshire
'24 TRD Sport Pr / prior '19 & '21 Tacoma Limited
The Tacoma has to be lifted in order for 285's to fit.
Hi Dubz. Great looking truck. So are you saying that a 285/70R17 is rubbing/won't fit at stock ride height? I think the stock offset is +45 as well if I'm not mistaken. I was thing of going with Falken WPs in a 285/70R17 on some Method wheels with a +35 offset. I've heard conflicting thoughts as to if they will fit at stock ride height with no trimming. What are your thoughts/experience? Also, what did you do for TPMS sensors? Thanks.
Mrknowitall
SE MI
20 Silverado, 22 XV
Is your suspension the same as the SR? Will that tire setup fit the SR?
the OR is a little taller up front and obviously has a different rear suspension from the SR. SR/SR5 tread width is also 1cm narrower, the base wheel off-set is probably 5mm greater.
Dubz
Dubz
Long Beach, California
Toyota Tacoma Off road
I believe that we all need some kind of therapy with purchasing these Tacoma's at these prices...:ROFLMAO:
