35s on Trailhunter - 25mm or 35mm offset?
bemmster
2025 Trailhunter Long Boi
Looking to pull the trigger on 35" Toyo Open Country AT IIIs (C Load). Deciding between RRW wheels at 25mm and Methods at 35mm.
Wanted to see if anyone had experiences with these on a Trailhunter and if any rubbing occurred on either offset. From what I'm seeing 35mm should be fine, wondering if anyone has done 25mm. I'm also going to be putting on Dobinson springs, 820 in the front and 819 in the rear so there will be a slight lift over the stock Trailhunter height.
Thanks in advance, if anyone has pictures of 25mm offset and how it lines up with the Trailhunter fender that would be much appreciated!
