6MT 1st gear throw not engaging
Bren
canada
2025 tacoma off road 6MT
Anyone else rocking the manual transmission?
Had the truck for little over a month now and can't figure out for the life of me, why 1st gear shift doesn't engage sometimes (go into the shift slot) feels like there's something binding or blocking the engagement.
It's mainly happens during from a stand still start. Grinded a couple times from these incidents, which is upsetting..
Afterword I try the same scenario, and it works buttery smooth. Only thing i can think of is the gear not aligning correctly with the shift lever from rolling slightly? Or am I bad at manuals?
never had this happen before with other manual transmissions.
But other than that, great transmission (engine rev hang took some getting use to)
Tacocho
Alex
Portland, OR
My transmission did something similar. I had to go into neutral again before it would smoothly engage 1st. After 4-5000 miles the issue went away. I think it’s part of the transmission getting broken in.
hobitz2izngard
Bren
canada
Good to k
Good to know. Even after going back to neutral a few times, still wouldn't engage. I hope your right, only at about 2000 mile.
stuckinsocal
24 TRD OR 6MT
Just stick it back in neutral, take your foot off the clutch and then try again. If you are bound up try putting it in reverse / different gear for just a fraction of a sec, then back into 1st. Happens sometimes on my other car (that I learned stick on, the poor thing) when it is cold / has been sitting a bit.
hobitz2izngard
Bren
canada
I'll give it a go, thank you
Mini2nut
FYI…
https://dot.report/bulletins/11007438
Some 2024 model year tacoma vehicles equipped with a rc60f manual transmission / transaxle may exhibit a condition where the vehicle is unable to shift into second, fourth, and/or sixth gear but is able to shift into all other gears. Further inspection shows signs of cracking from the floor shift control shift lever retainer sub-assembly housing. To address this condition, the manual transmission assembly needs to be replaced.
Here is a good thread regarding Tacoma manual transmission lubrication. Redline MT-90 seems to be a favorite.
https://www.tacomaworld.com/threads/best-gear-oil-manual.707033/
hobitz2izngard
Bren
canada
FYI…
Thank you for this info!
Haven't had any issues with the other gears, just 1st. I would assume/hope toyota had fixed these deficiencies with the transmission with the newer models rolling out. That being said, I'm going to talk with the dealership and double check for any manufacturer faults.
Will post results, if I remember lol
hobitz2izngard
Bren
canada
Makes sense,l I'll give a go!
