Aftermarket mud flaps for TRD Pro?
jackvz
Jack
richmond
2025 Tacoma Trd Pro
I took care of that funny little problem on mine with a Sharpie. I’m no artist but from about 25 feet away, it looks factory. I’m sure that you can do better than mine if you take your time.
Haha, that is one way of hiding the gap. But it doesn’t unfortunately add any protection
TX-BluStreak
Tom
Houston
25' TRD Pro - Underground
The crux of owning a "white" truck. Since mine is Underground...you can barely see the "gap" or the difference. But I might get the "thin" version of the Canadian mudflaps and floor liner for my truck (a late Xmas present to myself).
I’m neutral on the gap lol.
TRD DON
Don
Bowling Green, Ohio
2025 Tacoma TRD Pro
I ended up getting the Canadian flaps as they now don’t have that big bump on the inside and they were comparatively cheap and easy to install. That said, I’m worried they will get caught on a stick or rock and tear off. If they do get caught, in your experience with metal and knowing how fucking thin the rocker panel / fender metal is on our trucks (18 gauge?), will the bolt / grommet simply strip out or is it more likely the sheet metal will get bent and deform? I’m a little concerned because the grommets are really tight in there and I’m worried the metal will be damaged. If the RokBlokz actually installed properly I would have kept them.
Can you shoot me a pic of the Front flaps showing one inside of the flap? I got my (Larger) Canadian flaps inMay and they have the big bump out that rubs only 275/70/18 Terra Grapplers
