TacoFish
Bill
Snoqualmie, WA
2024 Trailhunter LB, 2023 Audi Q4 etron, 2025 Subaru Outback Wilderness
@TrailAdventurer I have had my Alu-Cab Contour installed for almost a year now, made the purchase on Black Friday last year. I sealed the bed rails with Aluminum Foil Tape and Sika Flex. Used the included butyl tape from Alu-Cab and some additional to seal the bed to the canopy. I installed tailgate seal kit that Mitch33 calls out above. I live in the PacNW as well, it gets wet here. I got some rain drops though in the first month or so. That seems to have settled and I only get any water through from running through car washes s or me hosing it down. Not that much at all. just a few drops in the front corners. Maybe some more butyl tape can resolve this.
After all the above, I was still getting more dust in that I wanted. There are a couple of things that I have done that has greatly reduced the dust.
1 - I used foam to seal the holes in the compressor kit storage compartment. You have to do those from underneath. I glued these in place. You need foam so that you can shut the door to the compartment. See pic.
2 - I cut out two 3 x 3 square foam pieces and attached these to each corner where the tailgate meets the canopy with two sided tape. See pics.
I now have noticeably less dust in the canopy. I get dust in the cab with re-circ turned on, so dust is inevitable. I am a clean freak, so the less dust the better.
2024 Tacoma AluCab Contour Canopy - Installed IMG_2781
2024 Tacoma AluCab Contour Canopy - Installed IMG_2778
2024 Tacoma AluCab Contour Canopy - Installed IMG_2780
TrailAdventurer
JT
Canton, MI
Good stuff. Thank you for sharing. I've got work to do in the off-season :).
