Aquarium in my Door ??? WATER in my Passenger door!
Canufixit2026
New England
2025 Tacoma SR 4x DC
I was hearing occasion strange noises when driving low speed on non perfect roads ..on bumps..
And, as I backed in/ up my driveway today - it's on a slight incline - I hit the brakes a tad harder than usual, and heard a SLOSH !!
Nope - not the gas tank ...
WATER - !! in my Passenger door !! Dual issues caused .. #1 - door bottom the one way flapper valves sticking shut (To allow drainage AND keep tire thrown water and debris out of the door) !!! #2 I purchased, last year, window vent top edges for 2 front windows ... So I can keep my windows open an inch without rain entering when parked - to let the heat out in the sun /summer when parked !! Opening the windows also opens the glass window bottom seal to the door exterior - allowing water to enter inside the door !!! DUH !!!
I drain it and need to adjust /lube the flap valves - and I hope the inside coatings of the door did not not rust through...
And I read that that sticking drain valves are a know issue and there is a TSB for this ....
Longpatterned
Tim
New Orleans, LA
Same. Hard rain or car wash. Sometimes my left rear door backs up with water. Dumb plug. Even then it seems to take a while for the door interior to dry. Definitely a Schlimmerverbesserung. <- Terrible enhancement.
Get a tooth pick, lift up the flap on the plugs, clean them out. Or just remove the most rearward plug on each door.
