Attempted Theft.
I agree with @Sagebrush, most break ins like that are kids looking for money, smokes, any loose valuables, not to steal your truck. It still sucks but I don't think you need to spend big bucks and go full tactical on disabling your truck.
Miqie
2024 TRD Sport-Bronze oxide.
In some ways, the old West knew how to handle things better than we do now. Mess with a man's transportation (his horse) and you were swinging by sundown!
trailhunger
2024 TH
If you are having issues with theft there are lots of options. Last time our neighborhood was getting cased - Step 1 was to pull the fuse to the gas pump.
good tip, I like that idea for the 'occasional' added piece of mind. The repetitive action over time on that fuse box though doing this every damn night...?
Delirious
Nick
Florida
Hope this helps
AI Overview
Yes, computer programs and cheap devices are readily available and widely used by criminals to steal modern push-button cars
. Sophisticated car hacking is a growing concern for law enforcement and vehicle owners because the theft can be done quickly and without causing any physical damage to the vehicle.
Thieves use different high-tech methods to bypass a car's security system.
  • Relay attacks: A pair of thieves can use signal-amplifying devices to perform this attack. One thief stands near the victim's house or building to capture the key fob's signal, and the other stands near the car. The signal is relayed, fooling the car into thinking the fob is nearby so it can be unlocked and started.
  • Key fob reprogramming via OBD port: In this method, a thief first breaks into the car by punching out a lock or window. They then plug a device into the vehicle's On-Board Diagnostics (OBD) port, which is usually under the dashboard. Using software, they can program a blank key fob to work with the car, allowing them to start the engine and drive away. This can take just minutes.
  • Code-grabbing and rolling code bypass: When you use your fob to lock your car, a thief can use a device to intercept and copy that digital code. More advanced attacks can even bypass the "rolling code" security feature found in modern key fobs, which is designed to prevent code replay attacks. Hackers can do this by intercepting a legitimate transmission to reverse-engineer the algorithm that generates the codes.
  • CAN bus attacks: This newer and more complex method involves breaching a car's Controller Area Network (CAN) bus, which is the messaging system allowing a vehicle's different electronic parts to communicate. By plugging a device directly into the CAN bus, thieves can reprogram it to create a new key.
How to protect your vehicle from high-tech theft
While these methods are effective, car owners can take several steps to protect their vehicles.
  • Use a Faraday box or pouch. The simplest and most effective defense against relay and code-grabbing attacks is to place your key fob in a signal-blocking pouch or box. This prevents thieves from capturing the signal from your fob.
  • Invest in a steering wheel lock. A physical deterrent, such as a steering wheel lock, can be effective in slowing down or deterring a thief, as it makes the car a less attractive target.
  • Install an OBD port lock. You can buy and install a physical lock that covers the OBD port, preventing thieves from plugging in their reprogramming device.
  • Use an aftermarket kill switch. An immobilizer or a kill switch can cut the power to your car's starter or fuel pump. Some aftermarket kits can be wired to your vehicle's system to prevent it from starting even with a programmed key fob.
  • Consider a vehicle tracking system. A GPS tracking device won't stop the theft, but it will significantly increase the chances of police recovering the vehicle.
Confucius say man who stand on toilet is high on pot 👈🏼Link
Your MT is deterrent enough for the 99.9% of average car thieves.
Don't listen to the. 223 with suppressor guy, what you need is something like a 300BLK with suppressor. Something subsonic to really be quiet and not draw any extra attention.
trailhunger
2024 TH
Would’ve loved a feature like pin code to drive or deep embedded electronic sequencing code through buttons on my TH! Certainly paid for it 🤙🏼
Miqie
I like how you think!
