Bak Revolver x4ts compatibility with Yakima Overhaul HD rack system question...
Greg Stevens
Greg
Utah
2025 TRD Off Road
Hey guys! I'm looking to pick up a revolver x4ts bed cover and am curious if the Yakima Overhaul rack system will work with it. Anyone running with this set up? I know the retrax system would work but with a 5ft bed, I don't want to give up any more bed space. Thanks!
nurp42
TRD PreRunner
Jeff
'24 PreRunner
I’ve got the cover you’re asking about and unless Yakima has made a design change, it’s not compatible w/ that rack——the vertical side members taper inward toward the top which will prevent (block) the cover from rolling forward. My solution was to go with the Elevate rack since the uprights are straight up which allows the cover to pass through when rolling up. Below, I’ll add a pic and link to the write-up I posted after install if you’re interested. FWIW, I’ve been very happy with this set-up and haven’t seen anything yet that looks like it would be better for my needs.
https://www.tacoma4g.com/forum/thre...olver-x4ts-elevate-rack-from-realtruck.13247/
2024 Tacoma Bak Revolver x4ts compatibility with Yakima Overhaul HD rack system question... curevel
Greg Stevens
Greg
Utah
2025 TRD Off Road
That does look pretty good. I appreciate the feedback.
doyleaa
Aaron
PA
I have that same tonneau cover and am running the Kuat IBEX rack setup. I know a couple other people on here have that setup as well. Here is a pic with the bike rack they have for it.
Can run in mid height which is what I have… or run it full height….there are molle panel options…. Even can fully enclose it with their panel system if wanted. DD has a bunch of different lighting options for it.
2024 Tacoma Bak Revolver x4ts compatibility with Yakima Overhaul HD rack system question... IMG_8326
Greg Stevens
Greg
Utah
2025 TRD Off Road
That looks really nice. How much weight can that bike rack support?
doyleaa
Aaron
PA
According to Kuat, it can hold up to 67lbs. I have several Kuat products, they are top quality and their customer service is hands down the best I have ever dealt with!
FlyAngler
NH
I'll second @nurp42 . I sold my Yakima from my previous setup/truck and went with the same as nurp42.
