Bed Power Port Power
4thgenmedic
Matthew
Tennessee
2024 Sr5
I
I am wanting to add this to my SR5, Does anyone know if the pigtail behind the left taillight is already wired and is it constant ? I am wanting to plug in my fridge when I off-road.. but if no constant power, I'll just run a new power wire.
2024 Tacoma Bed Power Port Power power port
CuriousTaco
Seattle
TRD OR Base
I've been wondering about this since the accessory was listed by Toyota PT949-35340. I have a TRD OR base and noticed the connector was present when I pulled the taillight off to install bed stiffeners. It's pretty hard to access from the tail light or below.
Someone with an upgrade or premium package will have to confirm if it's power supply depends on the the ignition power (ACC/ON) or the button that controls the AC power outlets. I'm expecting it's the ACC/ON because it's a 12v DC outlet.. at the end of the install instructions (attached) say to check the lights on the power ports when the engine is turned on.
The install seems pretty sketchy without 100% confirmation in compatibility. Huge hole and 4 rivnuts (or self tappers) to be a tester. I'm still tempted though.. would be super useful.
https://www.sparksparts.com/oem-parts/toyota-truck-bed-power-port-pt94935340
4thgenmedic
Matthew
Tennessee
2024 Sr5
I tested the plug work and without power.. no bueno… no power…
CuriousTaco
Seattle
TRD OR Base
Dang that’s a bummer. I’ve found so many capped connectors around the truck I’m starting to think most of them are useless without additional hardware. ?
jerrysoffroad
Denver, CO
2024 Toyota Tacoma OR
Just found this thread! (Curious Taco) Will have to add an additional power supply eventually to get to work without turning on?
zachavm
Zach
Oklahoma City
Subaru Forester & Subaru Ascent
So even if the wiring is there, I very much expect the inverter that drives it will not be there. That is some very expensive hardware and it would be crazy for Toyota to spend that money including it in trims not using it. However, if the wiring and hardness is actually there, it may be rather simple to install the inverter.
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
The connector is a beefy set of wires, which would also power the onboard air compressor (if you have a trailhunter, or bought the compressor afterwards). The instructions for installing the power port says the vehicle must be running for the power to be supplied. If this is true, I'm sure there would be a workaround for this once we figure out where the wires all trace to. Adding a switch with constant power (or ACC, to hopefully prevent too much battery drain) to the appropriate power relay would likely suffice.
Dman1351
Domenic
Pittsburgh
2024 TRD OFF-ROAD
I wonder if there is a fuse missing from the circuit on trucks not equipped with that option. I’m going to look into my Off Road at some point
Bjl0719
Brandon
West Virginia
I'm having this same issue! Few temp fixes. Cheaper and work!
Trailer 7 plug to DC (just can use when needed) or marine dc that can be wired to the battery without inverter
Blue Sea outlet
https://a.co/d/aYmII7P
Trailer adaptor
https://a.co/d/6DUyUOs
Has anything new came out? Are the existing wires there for the 12v and USB ? All plug in play? Any updates I’d like to get one for my non upgrade package sport
TrustButVerify
central
Several
So on my 2024 TRD OR, the plug is there tucked up behind the rear quarter panel. Pulled off the connector, set truck to ACC mode (lights on, but not running). It's a 4 plug connector. It has 12v power on two of the pins so the wiring is already there instead of running a cable to the back of the truck bed. It seems like it would be simply a matter of cutting a hole and installing this, but curious if it is that simple before I pick up a $200 part.
So it's already powered from the factory. Option 1 is buying the thing below. Option 2 is some sort of connector that connects to the 4 pin grey OEM connector but could fit some sort of spade or ring terminal and I could install a blue sea type connector.
Truck Bed Power Port
Edit: There was a similar thread to this on the TW forum. The plug supplies always on power, but also has a sense switch on the red and green wires. Tested it on mine. Find that, like on the other thread, it has power always. Per the wiring diagram, fused for 50A under the hood using an air compressor labelled fuse.
Looks to literally be a cut and plug process. Not necessarily faint of heart cutting into the bed to make large hole, but not seeing another way to access that plug without all sorts of malarky to build a custom harness since it needs a fair bit of work. Not my cup of tea, but would make a nice aftermarket solution to make custom harnesses and a single round 12v water resistant plug. Would then give power to bed without ever needing to run anything from battery. Not sure why Toyota needed to make this thing so damn big. So much wasted space on this when a simple plug, like every minivan in the world has, would work.
2024 Tacoma Bed Power Port Power 1757126162273-v8
Toy-truck
Houston, TX
I got an OEM truck bed power port available is anyone wants to buy it. It works. There is a little damaged to the flip cover. I upgraded to the OEM compressor/truck bed power port. I am selling it for $100 local in Houston, TX. Can ship via USPS large flat rate box for $30.
2024 Tacoma Bed Power Port Power IMG_5577
2024 Tacoma Bed Power Port Power IMG_5579
2024 Tacoma Bed Power Port Power IMG_5582
2024 Tacoma Bed Power Port Power IMG_5578
2024 Tacoma Bed Power Port Power IMG_5583
2024 Tacoma Bed Power Port Power IMG_5581
2024 Tacoma Bed Power Port Power IMG_5580
