Compass Needs Calibration; Is it magnetic or GPS/ Cellular based?
fredygump
Darren
Minnesota
2026 Tacoma SR5, 2016 VW GTI
I just realized that the built in compass is about 60 degrees off!
I thought I was driving North, but it turns out I was actually driving west... That explains why I never hit the highway that was just a few miles north of me!
Has anyone seen a way to calibrate? Or how does it detect direction? The compass is not stuck; it is just always off by about 60 degrees.
If it uses cellular data to determine direction, then I'm screwed. I disabled the DCM (i.e. cellular data). But I left the GPS antenna connected. I thought I already proved that Android Auto is using the GPS antenna, so a GPS based compass would still work.
Just to be sure it is actually the compass, I checked the declination. In my area it is almost exactly 0 degrees. And for fun I checked the declination at the Toyota factory in Mexico, and they are at 4 degrees. So it isn't like they caused an error by compensating for their declination..
This post made me check mine as I have the AutoHarnessHouse DCM bypass jumper installed.
Just as you have, my GPS is cracked out too. So the DCM is either acting as the GPS (satellite fed) or transfers the antenna signal to the ECM via the DCM harness.
