Differential oil change
LastBastion
Bruce
Ukiah CA
2024 Toyota Tacoma
I just had a 30K factory service. Seems like they did very little besides changing the oil and filter, and inspecting the floor mat. Admittedly, they say they inspected a few other things, but this so-called service cost me a very long wait. I was there for almost three hours, and struggled to stay sane.
Anyways, I read the manual and it seems the only significant additional maintenance required at 30K is to retorque the propeller shaft bolt. Oddly enough, they didn't do that. What I'm wondering is when I should get other fluids changed. Does anyone have recommendations?
Truckeeskibum
Neil
Truckee, CA
2007 TRD Sport Long Bed
I don't claim to be an expert at this and I'm sure there will be at least 27 different opinions on this issue, but I change the oil in the differentials and transfer case every 60,000 and the transmission fluid every 100,000.
FWIW, I'm at 210,000 on my 2007 V6 Long bed with no issues.
LastBastion
Bruce
Ukiah CA
2024 Toyota Tacoma
Thanks. I appreciate your advice. It does seem about right.
ColoradoBoo
Monument, Colorado
2026 Toyota Tacoma Limited Hybrid
Ah, the old "retorque the propeller shaft bolt"...is that still in the Owner's Manual?
I know a couple Master Toyota mechanics with a combined 50-year experience and not a single one said they've EVER found the propeller shaft bolt out-of-specs.
Unless you use the truck to tow, nothing else is needed at 30K but 40K requires front rear diff and trans axle fluid changes. (For 4x4....rear-rear drive trucks just need rear diff changed out.) You'll, also, want to replace the spark plugs with OEM Toyota plugs.
All these jobs are very easy DIYers, let us know if you need help.
