Front and rear locker options for SR5
chrismj51
Christopher
Denver, CO
2025 Toyota Tacoma SR5 4x4
I was searching around and couldn’t find much on lockers or gearing. I did see someone using the Eaton aftermarket 3rd gen e-locker for the front, but was curious if anyone has found a setup for either front and rear e-lockers or front and rear air lockers that would work with the SR5?
TacoKiwi
Barry
2008 Jeep, 2014 Q5 TDI
With front lock on IFS systems one has to be real careful when to lock and unlock due to CV joint/axle failure. Friend has a previous gen (2020??) 4 Runner with factory rear and added front lock and makes a huge difference. Eaton should be ok for front and rear if Toyo are not available. Gearing? There is a shop here in Calgary that can do gearing for them as they use the manual gears at 4.30 bought from Toyota.
chrismj51
Christopher
Denver, CO
I just had arb air lockers front and rear installed. Also regeared to 4.88. Happy with the results. Gears were revolution gear.
awesome! about how much did the setup cost and also what tire size are you running? What’s the rpm at around 65mph and any other positive or negatives for daily driving and offroad? lol sorry for the million questions.
559Taco
New Taco
Fresno
2025 Tacoma
5700 everything included. He did say the bearings in the rear were different than he was expecting and the front arb locker needed an adapter that he had to order from arb despite ordering the locker for the 4th gen.
I have ko2 285 75 17 E rated tires an method wheels. Power is definitely better after the regear. I'll let you know the rpms tomorrow.
I agree with being careful with the front lockers but they were awesome in the snow when needed.
559Taco
New Taco
Fresno
2025 Tacoma
True 65 mph rpm 2100. Gauge is 5% off with larger tires. 65 mph on gauge rpm 2300.
EatMyTaco
Murica
2026 Tard OffRoad
Just out of curiosity, how could the engine rpm be off? It’s just the speed that should be different. Rpm are measured at the motor, no? How could someone with a manual see rpm drop at speed in the middle of a shift or coasting on the clutch if the rpm’s were measured by wheel speed?
i do agree speed would be off because fewer rotations per mile due to diameter increase…
559Taco
New Taco
Fresno
2025 Tacoma
Yes. I agree. When my speed is stating 62 mph, im actually going 65 and rhe rpms are 2100.
BLtheP
TX
Can you elaborate on the parts they used? I haven't found anything that is advertised as fitting this generation.
559Taco
New Taco
Fresno
2025 Tacoma
Lockers
ARB RD271
ARB Air Locker for 2024+ Tacoma rear 8.2 differential
ARB RD121
ARB Air Locker for Toyota 8" reverse rotation front differential
Ring & Pinion Gear Sets
SG TOY8.2-4.88
4.88 ring & pinion gear set for Toyota 8.2 rear
SG TOY-TAC-4.88
4.88 ring & pinion gear set for Tacoma clamshell front
Rebuild / Installation Kits
IK TOY8-IFS
Complete rebuild kit for Toyota 8" IFS front differential
IK TOY8.2
Complete bearing & seal rebuild kit for Toyota 8.2 rear differential
BLtheP
TX
Lockers
ARB RD271
ARB RD121
SG TOY8.2-4.88
SG TOY-TAC-4.88
IK TOY8-IFS
IK TOY8.2
Thanks. Interesting, I can't find those part numbers but my guess is they are using the FJ/4R 8.2 gear set for the rear. Which we have the BD21C and technically I don't believe the FJ/4R do, but maybe whatever diff they have, uses the same 8.2" R&P anyways? I know the new Tacoma smaller rear diff and the FJ/4R are both 8.2", I don't believe the FJ/4R are the BD21C though. Gonna have to do some research on that.
I really want to put 5.29s in my truck.
559Taco
New Taco
Fresno
2025 Tacoma
Sierra gears
BLtheP
TX
Sierra gears
Ah thought you went Revolution. I am looking at Sierra's site and I see them and they are indeed listed for the 4R/FJ. Guess the gears are cross compatible with the Gen 4 Tacoma rear diff even though I don't think it is the same actual diff.
559Taco
New Taco
Fresno
2025 Tacoma
Yes. I thought they were revolution gear but I was mistaken. He used Sierra Gears. I believe R4T used revolution gear to replace theirs.
BLtheP
TX
Makes sense. Looks like they (Sierra) don't have 5.29 for that application. Wonder if Revolution does.
