Fuse for OEM air compressor on TH?
Taco Azul
MP
Portland
With the weather cooling down I got a couple tires showing low psi. No problem, I’ve got a compressor in the bed! Except when I went to use it nothing happens. It will not turn on. I’ve used it a few times before with no issues.
So I wanted to check for a blown fuse. I checked the fuse box under the hood and there are a LOT of fuses, but none marked for the compressor. Does anyone know where that fuse is?
SnowmanJPS
Halifax, NS
2025 TRD Pro
there's a big square 50a fuse that's labeled on my 25 pro as air comp however this isn't relevant to 2024 trucks because they changed so much electrical
Hatman
Argyle, TX
Old thread, but ignition is on and the parking brake is set? Both a requirement for the factory compressor to work.
Awger
Kelowna BC
24 Tacoma
I had the same thing happen to me and I was about to take it into Toyota and so what I did was I just went back and tried it one more time and I pushed really hard on the power button and it worked.
You probably have done this but thought I'd mention.
