Horizontal high beam adjustment
TheOldObiWan
Josiah
2024 Taco
Okay. I have a 24 TRD OffRoad Premium and I am aware of the vertical adjustment in the cabin for the headlights and highbeams.
I am curious if anyone else feels like their highbeams are angled inward and if there is a way to adjust them independent of the normal beams.
Everything I'm finding either refers to previous generations or the dial for vertical adjustment.
I genuinely feel like my low beams are angled well but my highbeams are crosseyed and don't project out to the sides of the road.
Thanks in advance!
Mercedes
≈39N
2026 TRD Sport "Mercedes"
I've tested mine a few times while driving. I did't notice an inward pattern, but I can understand if there is one: spreading it out could blind oncoming drivers while affecting our central vision.
Old school manuals had left/right and up/down adjustments available. But modern lights project a tailored shape. Assembly techniques involving body panels are tighter now so any "slop" doesn't need to be compensated for.
I haven't found anything that allows for that beam pattern to be modified. I haven't found a left/right adjustment while general googling modern cars and trucks with projectors.
This TW thread shows the pattern and explains its shape.
https://www.tacomaworld.com/threads/head-light-projection-pattern.850743/
This YouTube video, while it talks low beams, it mentions a "hot spot", an intentional bright spot, in the center of the projection. I suspect it's there to support the macula in the center of our eyes and our overall vision.
The truck is under warranty. If your dealer has a collision center, maybe stop by for a quick Q&A. If they find something off, they might be able to shim a bit or have a trick to get things back into tolerance.
https://my.clevelandclinic.org/health/body/23185-macula
Edit,
I had a chance to check my lights against a walled background just now. They don't seem to be pointing inward at all. There might be a procedure the body shops use to confirm things are set the way they're supposed to be. I'd chat someone up at a shop.
TheOldObiWan
TheOldObiWan
Josiah
2024 Taco
Edit,
Thank you for this. I will get a few pictures to see if you're seeing what I'm seeing
TheOldObiWan
TheOldObiWan
Josiah
2024 Taco
Edit,
In this video. When she turns on the high beams she says how there's very little peripheral light. This is what I'm talking about.
Mercedes
≈39N
Thanks for the reference. I see what you're saying now.
Ya, I suspect that's something baked into the design, primarily to keep from blinding oncoming traffic.
I re-googled several key words. In the latest models of any manufacturer, I could not find a reference to adjust the beam left or right. A body shop could confirm.
OminousSkitter
Alaska
I too suspect it's baked into the design. As someone with the OEM lightbar, I like the high beam pattern. It has better throw down the road than my previous vehicles, and the lightbar adds spread when I need it. I know my headlights are a little different, too, so Toyota could have had different patterns based on trim/options.
