Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
Hybrid Tacomas place the battery under the rear seat, which is problematic if you want to install a winch or other high-draw electrical components under the hood. Our Winch Power Distribution Kit solves that issue.
We pair our distribution block mount with an 8-stud bus bar, add some super high-quality USA-made 2-gauge wire, and complete the kit with a 500A MEGA fuse with holder. Everything you need to get power where you need it.
https://www.victory4x4.com/product/VT4PDR.html
Designed to add a convenient place to connect a winch and other electrical accessories under the hood of your Hybrid Toyota Tacoma. This is a full system, including mounting bracket/hardware, and all wiring/electrical components.
  • Includes a 500-amp MEGA-fuse and holder (imported).
  • Includes a bus bar distribution block with (8) M8 studs and covers (imported).
  • USA-made 2 AWG pure copper, dual-layer insulated wiring with a TPE jacket.
  • USA-made distribution block mounting bracket cut and formed from .120" steel and coated with a two-stage satin textured black powder coat over a durable zinc primer finish.
  • Proudly designed and assembled in the USA.
Snickers
Midwest
2024 Tacoma Trailhunter 5ft bed
Missing the place where you can put a relay or cut off switch. Mind mocking it up and showing us?
Victory 4x4
Victory 4x4
Daryl
Portage, MI
'24 TRD Pro
Pretty limited on space under the rear seat to put a cut off capable of handing winch amps. Did you have some other use in mind?
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
This is amazing and 1500 bucks cheaper than the competition! Victory for the win
