Icon Top Hat Reinforcement Installation and Torque Spec
Deleted User 412290
I was looking around and seems like some folks made this more complicated than it needs to be, so just wanted to throw a couple pointers and the torque spec out here for anyone looking.
First off, you do not need an extension on a socket through the engine bay to remove or install the bolts. I used a 14 mm wrench from the wheel well, loosened, then removed by hand.
After installing the top hat reinforcement I tightened all bolts by hand then tightened the remainder of the way with a torque wrench to 33lbs.
2024 Tacoma Icon Top Hat Reinforcement Installation and Torque Spec 2213
After the reinforcement plates are on, the studs are short enough to get to all of the bolts with an 80# harbor freight torque wrench and standard 14mm socket. Yes, I know a HF wrench is not as accurate as something high quality, but it's what I have 🤷‍♂️
Side note: I didn't spend time verifying this torque spec diagram, so double check for your own rig.
Cheers
CharlotteBlue
Ilya
Charlotte, NC
2024 Tacoma TRD OR Hybrid Premium
I did mine a few weeks ago, pretty sure I have the same cheap-o Harbor Freight torque wrench but I couldn’t get it to fit over the two rear bolts. Going in from the hood with an extension was pretty easy though.
