- Joined
- Jul 27, 2024
- Threads
- 7
- Messages
- 61
- Reaction score
- 55
- Location
- Alberta Canada
- Vehicle(s)
- 2024 TRD Sport Premium
Not yet I'm MST time zone...lol
so am I it's been dark here for hours...Not yet I'm MST time zone...lol
I've attached the pdf installation instructions which are fairly straightforward, but to provide power to the illuminated emblem you are required to connect to the Daytime Running Lights (DRL) 3-Pin connector which is located under the cool air intake on the right-hand side of the truck. I need to confirm which cable needs to be disconnected and reconnected to the illuminated emblem cabling ports. I am trying to avoid having to take the truck to a Toyota technician which will probably take five minutes. Any help in identifying the DLR cable connector on the right-hand side below the cool air intake would be appreciated.Has anybody installed the illuminated Toyota badge for the front grill?
PT# PT413-35240
Yeah, i installed mine a few months ago. I like it.I've attached the pdf installation instructions which are fairly straightforward, but to provide power to the illuminated emblem you are required to connect to the Daytime Running Lights (DRL) 3-Pin connector which is located under the cool air intake on the right-hand side of the truck. I need to confirm which cable needs to be disconnected and reconnected to the illuminated emblem cabling ports. I am trying to avoid having to take the truck to a Toyota technician which will probably take five minutes. Any help in identifying the DLR cable connector on the right-hand side below the cool air intake would be appreciated.
It's the turn signal bulb plug. Just unplug it, plug in supplied cable and replug the bulb. Fairly straight forward. I installed mine 2 weeks ago.I've attached the pdf installation instructions which are fairly straightforward, but to provide power to the illuminated emblem you are required to connect to the Daytime Running Lights (DRL) 3-Pin connector which is located under the cool air intake on the right-hand side of the truck. I need to confirm which cable needs to be disconnected and reconnected to the illuminated emblem cabling ports. I am trying to avoid having to take the truck to a Toyota technician which will probably take five minutes. Any help in identifying the DLR cable connector on the right-hand side below the cool air intake would be appreciated.
If you don’t have a tool, you can also just feel for the tab behind the bottom of the emblem, lift that and it comes right off without any damage. Incredibly simple.Kind of, but not really. it’s a little hard to describe, but it does peel off if you want to. It’s pretty durable. I’ve seen people plastic dip wheels in it last five years. The logo should be fine. since it’s got plastic properties. It looks like the plastic surrounding the logo on the grill. I popped off the logo using cell phone tools. I’ve also seen people use feeler gauges to pop it off . just go, gentle, and it’ll be fine. It comes in a spray. Can get it at Walmart, or I got mine from Amazon.
Just installed mine on my Limited. I went with the dark chrome. I like it, but it does stick out from the grille a little.Can you take a pic or two at night? Thanks
there's also a black chrome option, thats the one i went with and it blends in pretty nice.I have the illuminated OEM emblem on my black 25 TRD Sport. Everything is blacked out except for that emblem and I wish it was black also. Looking for an overlay that may cover it but allow for the light to pass through. I will take a pic of the emblem at night with the lights on.![]()
Yes , it’s just have a darker toneDo you have a picture of the dark chrome one?
