Looking for good Bed Storage options
Delta1Seven
Does anyone have any good ways to mount weatherproof storage containers to the inside of the bed, similar to the ones below?
I'm looking for a good place to keep tow straps, jumper cables, etc. I'm not a huge fan of the Milwaukee containers, only because they are bright red and say "steal me, I'm expensive"
2024 Tacoma Looking for good Bed Storage options 1739801809459-bu
Berno
Laguna Beach
2001 Tacoma
Check out the OZ Tech Burro utility slide or Kaizen Source Taco Mounts. There are a lot of options out there for Packout boxes.
4g hybrid
I went with two gray Plano tool boxes from Home Depot. Weather tight. Less than $20 per. Easily moveable and tuck in cleanly under my retractable tonneau cover. When the rubber mat is in place, they don't move a cm. When it's not, they can slide around a little bit depending on a hard turn or bump. One contains more emergency gear like gloves, blankets, etc. the other contains more recovery gear like inflator, straps, soft shackles, etc.
It was the best solution I could find right now for something that maximized the space under the cover roll without extending past it.
Viper_00
Walter
VA
I got one of these swing out boxes. Takes 2 seconds to remove when I need more room. Also comes with a lock/key
2024 Tacoma Looking for good Bed Storage options IMG_4594
