Newbie! What tools do I need to install oem running boards and tonneau cover
Madmac9
Phoenix
2024 tacoma trd sport
I feel like a dummy because I know little about tools/working on cars. I'm going to have a friend help me but I want to make sure I bring the correct tools and not assume he has them.
I may have gone in over my head but I bought PT954-35240 and PT938-35240
Do I need to buy a 1/2 and 3/8 socket set and 1/2 and 3/8 Torque wrench?
Do these sets include 3/8” Drive Short extension or is that separate?
Same with 1/2” Deep Well Socket, is this separate?
Same with T-30 Torx Driver is this separate?
Same with 6" Extension
Anything I'm missing?
As you see I'm just lost on what I need and I'll probably be buying stuff on Amazon I don't need so if someone could point me in the right direction I would be forever grateful.
One final thing, I see conflicting information about needing or not needing to drill holes for a drain tube for the cover. Is that required? On my old tacoma I had a soft cover that didn't have any drain tubes so this is new to me.
Sorry for the silly questions! Hoping this will be a great learning experience so I feel more comfortable working on cars and have the tools needed!
2024 trd sport
BIGPZA
Michael
Long Island, NY
2024 TRD Off-Road
The first thing you should do is buy yourself a proper 3/8 drive socket set with a ratchet and a full compliment of SAE and metric sockets and adapters. You will find yourself using it literally every time you work on your truck, so I'd recommend springing for a decent one. A quality socket set will run you around $150-200, but you could go the Harbor Freight route and get a set that includes everything you'll need for about $50, just don't expect it to last.
It would also be a good idea to buy a drill/driver, a set of HSS drill bits, and a set of assorted screwdriver bits (just make sure it includes Torx bits T20-T40).
I also wouldn't recommend buying tools on Amazon.
Madmac9
Phoenix
Thank you!
OldOre
AC
TEXAS
2024 TRD OffRoad
If you tighten everything by hand, you don't need to buy a torque wrench, but I'm old and I'm sure some folks will disagree.
trailhunger
2024 TH
And get a little anti seize if you’re feeling fancy. It’ll save your ass in the long run when if/when you need to back out some of those bolts.
Or, you could join the dark side and use red thread locker on everything
Or just get some vibra-tite 🤙🏼
