- First Name
- Michael
- Joined
- Nov 5, 2024
- Threads
- 15
- Messages
- 39
- Reaction score
- 56
- Location
- Grand Bay, Al.
- Vehicle(s)
- 4G SR5. TRD upgrade package
Do you have a tutorial for the install?
Our website has all of our instructions uploaded, we also have install videos on our YouTube ChannelDo you have a tutorial for the install?
Any update whether this front setup would work as expected (2" front lift while preventing top hat failures)?@Peak Suspension
Entertaining the idea (if its necessary to prevent top hat failures) of running the Peak rear spacers (1" lift), front lower spring spacer (1" lift), and a TheTacoGarage billet strut reinforcement plate (1" lift).
On paper that would result in a 2" lift in the front and a 1" lift at the rear.
I didnāt end up with that set up. On an older post from thetacogarage, they said that their reinforcement plate is a 1/4ā thick at the base (not including the part of the plate thatās machined to go over the failure point of the stock top hat).Any update whether this front setup would work as expected (2" front lift while preventing top hat failures)?
Hereās my thoughts on this. Any preload spacer is going to move the equilibrium position of the shock valving closer to the bottom of the tube. This will cause the shock piston to need to travel farther and compress the spring harder in order to bottom out. This wonāt āpreventā top hat failure but will require a much harder hit in order to cause a failure than it would in stock form.Any update whether this front setup would work as expected (2" front lift while preventing top hat failures)?
The way the front suspension works for Tacomas in the past, and the 4th gen isnāt an exception, the top hat spacer thickness does not directly correlate with how much lift it will actually have on the truck once installed.Hereās my thoughts on this. Any preload spacer is going to move the equilibrium position of the shock valving closer to the bottom of the tube. This will cause the shock piston to need to travel farther and compress the spring harder in order to bottom out. This wonāt āpreventā top hat failure but will require a much harder hit in order to cause a failure than it would in stock form.
I just received the Peak 1ā preload spacer and a 1ā rear and 0.75ā top hat spacer from another company. Should give me 1.75ā front and 1ā rear. I donāt bag my truck off-road, but should give me some more room to absorb a hard hit without hitting bump stops. And maybe a little more peace of mind that Iām better than stock.
Yeah Iām aware of the suspension ratios. The top hat spacer I have is 3/8ā thick so I wonāt have stud length issues and it will indeed give me 3/4ā of lift. I just call it (maybe incorrectly) a 3/4ā spacer because thatās how much lift it will give me.The way the front suspension works for Tacomas in the past, and the 4th gen isnāt an exception, the top hat spacer thickness does not directly correlate with how much lift it will actually have on the truck once installed.
So with the 1ā preload spacer, and the 3/4ā top hat spacer you plan on getting, it will not give a 1 3/4ā lift.
The peak 2 piece front kit is a 1ā preload spacer and a 15mm top hat spacer that translates to a 2 1/4ā front lift.
If you were to attempt the 3/4ā top hat spacer, itāll be more than 2 1/4ā and not to mention youāll likely run into stud length issues previously mentioned by peak customers.
What brand/model is your 3/8" spacer?The top hat spacer I have is 3/8ā thick so I wonāt have stud length issues and it will indeed give me 3/4ā of lift. I just call it (maybe incorrectly) a 3/4ā spacer because thatās how much lift it will give me.
Mine is the Cornfed 3/4ā (3/8ā thick) top out shim. David was really great to deal with.What brand/model is your 3/8" spacer?
Thanks! Looks like Cornfed has a 1/4" version of the top plate also, which combined with the tacogarage plate, is 1/2" total thickness, giving 1" lift. Combined with the Peak 1" pre-load spacer, that should result in 2" total lift with a touch more thread left on the top hat bolts than the 15mm Peak spacer.Mine is the Cornfed 3/4ā (3/8ā thick) top out shim. David was really great to deal with.
ATH Fabrication has a shim that gives 3/8ā of lift which might work on top of the Tacogarage lift. https://athfab.com/product/3-8-lift-spacers-for-2024-fourth-gen-tacoma/
Right, I forgot Cornfed had a smaller plate for 1/2ā of lift, that would probably work too.Thanks! Looks like Cornfed has a 1/4" version of the top plate also, which combined with the tacogarage plate, is 1/2" total thickness, giving 1" lift. Combined with the Peak 1" pre-load spacer, that should result in 2" total lift with a touch more thread left on the top hat bolts than the 15mm Peak spacer.
I wouldn't mind the 3/8", but I lose about 1mm of thread over the Peak setup.
I'm definitely not taking my truck to the Baja 1000 or anything remotely similar and fully understand the tendency for problems to be highlighted on the internet. This is just cheap insurance if I'm already doing some suspension work up front, knocking out 2 birds at a time, even if one of those birds is just a sparrow.It's also worth noting how the top mount failure was achieved in the first place. If you jump your truck with stock suspension or stuff it into whoops incorrectly, the top mount failure can happen, regardless of any type of spacer lift combination or none at all.
With the internet, failures always seem to be more prevalent than they actually are since it tends to be an echo chamber for reporting problems or complaints, so it's always worth keeping those thoughts in the back of your head vs worrying about it all the time.
