Recovery Board Mount for roof rack
bsquaredMTB
Ben
El Paso, TX
I recently purchased these recovery boards
https://a.co/d/29P0ogC
I'm curious if anyone has any suggestions as to how to mount them to my roof rack T Track system. I'm not super clear on the best way to tighten the mount to the rack
2024 Tacoma Recovery Board Mount for roof rack PXL_20251022_013648629
2024 Tacoma Recovery Board Mount for roof rack PXL_20250922_222122250.RAW-01~2
TFOUTS
Timothy
Northwest Florida
2024 Tacoma Trailhunter, 2003 Tacoma TRD OR, 2003 Toyota Sequoia
Those look like all top boards and in the Amazon all top store, they have universal mounting pins for T slots
https://a.co/d/d0ATv1v
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
Right, but I'm not clear on how to mount onto the the t-track. My current plan is to use the hex bolts and washers I circled in the picture in the t-track slot with the bracket and posts sitting on the t-track. My problem is once I get the hex bolts and washers in the slots I can't figure out how to tighten everything down
2024 Tacoma Recovery Board Mount for roof rack PXL_20251023_151730750.MP~2
TFOUTS
Timothy
Northwest Florida
You don’t need that bracket, mount the pins directly onto the track using T slotted bolts and screw the pins onto the bolts.
2024 Tacoma Recovery Board Mount for roof rack 1761233439762-vr
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
I thought about that too but the bolts are too wide to slip into the slots on the rack. For that to work I'd have to remove the t-track everything I want to mount the boards
2024 Tacoma Recovery Board Mount for roof rack PXL_20251023_153452874
TFOUTS
Timothy
Northwest Florida
This is assuming you bought the board mount kit
bsquaredMTB
bsquaredMTB
Ben
El Paso, TX
I think you solved my issue. My boards didn't come with those t-track inserts! That's what I need. It did come with the kit but for whatever reason, the kit was missing the t-slot mounting part
TFOUTS
Timothy
Northwest Florida
Yeah, that’s usually the way it is, if you buy Maxtrax that’s all you get, the mounting hardware you usually purchase separately because there’s so many variations for mounting.
