Revisit Towing without Brake Controller
Mulepadre
Arkansas
2024 Tacoma Off Road, 2003 Tacoma Sgl. Cab 5 speed
Like many my 2024 Off Road does not have a brake controller.
I am considering a 2060 lb (dry weight) camper to travel with.
I would be towing in "sport mode" at best with a manual transmission.
I've looked at all the posts and want to conclude that this is a bad idea, true?
Camperbunga
Connie
PA
2025 tacoma TRD OR
The 2024 doesn't have the plug included in the harness in the 2024 or 2025 tacoma for a brake controller. I just installed the tekonsha wireless controller yesterday. It's pricey but better than the Kurt wireless which you control with I phone. The tekonsha wireless has a handheld controller which I feel more secure with. You should have a brake controller and watch you tube videos on how to use it, for instance, if you experience sway, you apply trailer brakes before truck brakes. You have to screw the controller into the trailer frame which I was worried about but miraculously, the holes were already in mine. I guess the trailer dealership put my travel trailer on a frame someone had before that had the same controller. Damn was I happy. But yes, you should definitely have a brake controller.
Here's a whole thread on the topic: https://www.tacoma4g.com/forum/threads/brake-controller-harness-for-4th-gen-tacoma.2433/
goin2drt
KY
Yes it is a bad idea. Unless you are just pulling some light utility trailer it is not recommended to not use a brake controller.
TrustButVerify
central
Several
Depending on where you go, it might also be illegal. Some states require trailer brakes over 1000lbs, some 2000lbs. Cheap insurance to get a controller, especially if you get some sway. When the trailer is sideways, you'll kick yourself for not springing a few hundred for even a wireless controller.
