Safety sense recalibrated after lift?
mjohn185
Michael
Roswell, GA
Considering having the Westcott collar lift installed and have seen mixed results with trucks have error messages for the Safety Sense after this or level kits installed. Anyone that has had level done on truck, did you have issues afterward? If so what was done to clear and correct issue? Thanks in advance!
bking
Bernie
2024 Tacoma TRD Offroad
I did my Westcott lift myself, and no issues with safety sensors needing recalibrated. The service manager at my dealership was surprised it didn't need recalibrated when they did the alignment after, but he said it may because at this point I only have 33's and that larger tires may require alignment.
Wescott has a video specifically explaining that you need to be certain when jacking up your pickup to install the lift the keys are no where near your pickup for At least 10 minutes. The ECU may think it was in an accident causing the sensor problems.
HCTacoGuy
Jerry
Pa
2025 Tacoma TRD Sport
I had the Ready Lift SST 2.5/1 installed and didn't have any issues with the Safety Sense.
mjohn185
Michael
Roswell, GA
What are your thoughts on the SST after having it installed? Are you pleased or have any complaints?
HCTacoGuy
Jerry
Pa
I love it. Ride is basically the same as before the lift. Maybe a slight bit more roll on sharp turns but otherwise still rides great. Would highly recommend.
2024 Tacoma Safety sense recalibrated after lift? IMG_2396
mjohn185
Michael
Roswell, GA
Thanks for the reply! Truck looks really good. Considering going this route with mine.
