SXTH Bed Step relocation bracket - tweak needed
TrailAdventurer
JT
Canton, MI
Howdy,
A few months ago, I ordered SXTH’s bed step relocation bracket. The concept is solid, and installation was straightforward. But I ran into a problem: when raising the step, it interfered with the recovery hook by about 3/16"—not good.
To their credit, SXTH’s support was top-notch. They identified an incorrect bend angle in my batch and quickly sent a replacement. Unfortunately, the new bracket still had the same issue—just at a slightly different interference spot. Still unusable.
My workaround was to stack two ~3/16" thick fender washers on each mounting bolt, shifting the step outward just enough to clear. But that introduced a new problem: the bolts only engaged about half the nut depth. As a last attempt, SXTH sent me a pair of coarse-thread bolts that were far too long.
If you run into the same issue, my final solution was to use four large washers (two per bolt) and picked up a pair of M16 x 140mm bolts from a well-stocked hardware store. That did the trick.
While the weeks of troubleshooting were frustrating for what should’ve been a 20-minute install, I’m now happy with the result.
Hope this helps—FYI!
2024 Tacoma SXTH Bed Step relocation bracket - tweak needed 1768758022529-yd
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Thank you! I’ve got one of those brackets to install. Got it a few months ago. Appreciate the info in case ours doesn’t fit right.
myhikingboots
Chuck
Atlanta, GA
A guy on this forum, I forget his name, had the same problem and got a new one from Sixth Element and he gave me the defective one. I ended up drilling out the big hole on it slightly and rotating it away from the recovery point and it works fine with the Amazon step I purchased.
GoodMoodley
Ontario Canada
2024 TRD Off Road Premium, 2023 CRV Hybrid Touring, 2015 228i xDrive, 2012 135i
I have the same issue as well. A little wonky looking. Will shim it at some point.
2024 Tacoma SXTH Bed Step relocation bracket - tweak needed IMG_0338
shackley
www.swxrflab.net
Howdy,
That’s great. Do you have a link for the step, or is it a Toyota one? I was hoping Toyota would come up with one by now with a similar mod.
mikeymtbs
Atlanta, GA
24 TRD Offroad Premium
Glad it worked out for you!
The replacement I received from SXTH worked perfectly with no modifications. FWIW, the OE bedstep, which I’m sure is a port add on, is an AMP labeled product.
myhikingboots
Chuck
Atlanta, GA
Thanks again Mike! Saved me $60!
SnowmanJPS
Halifax, NS
2025 TRD Pro
Howdy,
This was my idea also, but that bracket costs $180 here in Canada after taxes, I will be asking for a new bracket if mine isn't perfect, or I'll template it and make my own in the shop (fabricator)
TrailAdventurer
TrailAdventurer
JT
Canton, MI
shackley
www.swxrflab.net
Many thanks. I’m 5’8” and 76. This will be a great help. I’ll let my dealer parts guy know and they might refer them to others.
Thanks again JT. I ordered it and the lower control arm skid plate. I'm coming from a Jeep Gladiator the suspension of which doesn't have lower control arms - one of the few things that I liked better on the Jeep.
