What is the tire pressure for 285/70/17?
astroboy
Southern California
I am running 40 on my KO3, 285/70/17. Called the manufacturer and was told that that is the optimal for our truck. Rides is a tad bouncy, but will help in maxing out the tread life of the tire per manufacturer. I am just winging it and going by what they said, hoping they are right. ?
Powhunter
Alberta
ā€˜24 TRD OR 6MT DCSB Underground
Keep an eye out for more wear in the center of the tire. I was running 40 on my 285/70R17 Toyo R/Ts and the outside of the tread wasn’t even touching the road on the rear tires. I’m running between 30-35psi now and it seems to be better.
Yeah 40 is way high. Load tables point to 30 for SL and 35 for C/E load.
astroboy
Southern California
I personally think that 40 is on the high side. I just went by what I was told for it was the manufacturer who gave me those numbers. After reading what you said, I will have to do the chalk test now I suppose, to see what the ideal numbers are for me.
jahferg
Jahson
25 TRD off road
Yup always run 40 or 42 seems the best for s load 285 70,s, always have 800lbs in back bed also
slater
san diego
2024 tacoma sr5/2wd, white
I have the same tires on my sport.
Per the calculator & per tech support at Falken
30 PSI
slater
san diego
just realized this is an old post....
