DENNISD
Dennis
Omaha
I really wouldn't even call it poke. To me it just looks flush and not sunk in like oem.
That is one SHARP Truck!! These Gen 4's are just simply awesome in the looks department!!
xianmacx
Cincinnati
2025 Tacoma
Thank you. I really love this truck. I had a 24 land cruiser and I like this so much better.
Amorak
Oklahoma
2025 Tacoma TRD Pro, undergound w/ red interior
I'd be surprised if you noticed it much on a hybrid. The hybrid has larger 18" wheels and the same outside diameter (~33") stock tires. KO2 C-loads are lighter than your SL Wildpeaks. And of course the hybrid has ridiculous low-end torque.
When I stick 285/75R17s on my inbound '25 6MT your statement will probably be VERY applicable though. Going from 36lb to 59lb tires is likely going to lose a lot of pep.
Stock Falken WP SL's @265/70/18 are 38 lbs.
KO2 C Load @285/70/17 are 51 lbs.
MustardTiger
TacoMAX/SDuty/Dmax
703’s, +35, 285/70r17 Wildpeak AT4 SL’s.
I used Autel MX sensors that I programmed to match the factory sensors, and also used the hub centric rings posted in the last pic. Everything fits great. Feels like much larger tires can fit without issue, but who knows. So far I honestly have not noticed a loss in power or ride comfort. Tires are at 37 psi
2024 Tacoma Method 703 + KO2 285/70/17 IMG_4031
2024 Tacoma Method 703 + KO2 285/70/17 IMG_4025
2024 Tacoma Method 703 + KO2 285/70/17 IMG_4014
T4coTuesday
British Columbia
2025 Tacoma TRD OR Premium Hybrid
Are those the XL high clearance rokblox or just the regular high clearance?
T4coTuesday
British Columbia
Xl high clearance
I think i might have done goofed. I just ordered the standard high clearance thinking i wont need the extra width, but i plan on going with a +35mm offset wheel as well. Although I'm going with a 275/70R18, but still by looking at your pictures i think i should have gone with the XL's... Do you have a pic looking straight along the side of the truck?
MustardTiger
TacoMAX/SDuty/Dmax
I don’t atm. I believe the difference on the xl is 1/2” extra width on the fronts, and then just added length both fronts and rears. With a 275/70r18 you should be just fine with the regular high clearance
T4coTuesday
British Columbia
Thats a relief.
Your truck looks amazing though! What did you get for the front badge and the rear tailgate inserts?
MustardTiger
TacoMAX/SDuty/Dmax
Thats a relief.
Thanks! So the front badge is just plastic-dipped…easy to pop off and coat it. The rear Tacoma insert letters are from Amazon. It’s black with a red outline
bronzilla
chris
colorado
2025 Tacoma Off-Road
With the +35 offset have you noticed much rock chipping on the rear panels from rocks flinging up? Do you little ark mud flaps actually do anything. I’ve got +20 offset wheels and seriously considering switching it up before I have no paint left lol
