N8thanJ
CA
Hey there, just wanted to share the new style CV on the TRD Off Road. Pretty weak C clip holding everything in. Don’t accidentally pull it out 🫣. Lol. Boot is currently not available.
2024 Tacoma New CV design - 2024 Tacoma TRD Off-Road IMG_5260
2024 Tacoma New CV design - 2024 Tacoma TRD Off-Road IMG_5261
Sner
It is not a new design and has nothing to do with a Toyota issue. All inner CV joints on all cars are of a tripod or tulip style. They all come apart the same way, if you pull on an inner CV joint the wrong way the boot could tear and the joint will come apart.
All professional mechanics know that.
N8thanJ
CA
My apologies “new to me”. I must have only seen the other style you referred to. The boot did not tear, the C-clip came off and made a small puncture from the inside. Thank you for sharing your knowledge. Not blaming Toyota, it was my fault.
N8thanJ
CA
Why did you remove it?
I was changing my suspension and my support for the CV, brakes, etc. let loose. The weight and angle must have been just right to pop out that c-clip. Couldn’t reassemble without removing the boot.
izzy
Bay Area
The axle and all associated parts are covered by your warranty, unless Toyota denied you service.
Edit: Oh, didn't refresh the page, makes sense now 👍
