Aulric27
ND
2025 Tacoma TRD OR Hybrid
OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution!
I know there are plenty of posts out there that claim they’ve solved the noise issue with these roof racks. But this is the real fix. Usually the fix claimed is by performing the TSB issues to install longer pegs, and while that may solve the horrid vibrations noise, it doesn’t really quite down the rack. This rack is without a doubt one of the loudest, nastiest wind noise makers ever produced en mass. Even with the new pegs installed it generated a horrible wind noise. It sounded like you were doing 120mph when you are only doing 70. Awful.
Well here is a proven solution to that noise and at a convenient cost of less than 20 dollars (assuming you had Toyota fix the TSB warranty for free). All you need is an automotive front splitter trim piece, yep those cheap little rubber lip ad ons that every body kitted on a budged Honda has. You also need some paint protection clear film. Just a strip of it. And some paracord.
Attached are the pictures of the process, not quite in chronological order but there really isn’t a right or wrong way to start this. That being said, you do need to pull your front fairing off before you start. It’s easy, 6 Torx bolts and you’re done.
Start by cleaning your surfaces. Pictures provided do not show clean surfaces but it’s important. Measure and apply trim piece to the lower edge of the fairing. Trim the edges to round out for a nicer look. Leave about an inch or so of trim poking out. The trim has an elevated section where the tape is that fits nearly perfectly with fairing indent so it’s pretty easy to line up. Put ppf strip over paint where the edge meets the body. Reinstall. (I did this step backwards and it was a bit annoying to put the strip on once the fairing was on.
Add second trim to the rear fairng edge. Cut and trim as needed. Pretty straightforward.
Wrap cross bars with paracord to reduce turbulence of air passaging over them.
And that’s basically it. With some trial and error testing it took me a little over an hour. The job itself is only about 15 minutes.
The difference is astonishing. I already had the TSB completed and was still getting decibels around 80 when driving into a head wind. With the modification the decibels were low 70s and that improvement cannot be overstated. Without the roof rack cab noise would be around 68-70 in similar conditions. So the mod brings the noise level close to not having the rack at all. Mpg tests were not performed because in the great white north we have really heavily blended winter fuel so no matter what the MPGs are trash. Maybe I’ll do an update this summer.
Anyways, thanks for the read!
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7767
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7768
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7769
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7770
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7771
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7772
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7773
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7774
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7775
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7776
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7764
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7765
2024 Tacoma OEM ARB Toyota Roof Rack noise issue fixed. The Real Final Solution! IMG_7761
timmers
Penticton, BC, Canada
2024 4G Tacoma Sport Premium
Thank you for this detailed and itemized write-up. I've been working on solving the wind noise on my 2024 Sport as well. You've provided me a very helpful way forward from what I've already done. Virtual high 5 and hug from me!
TacoRaptor
North Carolina
2025 Tacoma Trailhunter
I found that simply adding roof boxes onto the rack fixed the roof rack noise on my TH. Now I have roof box wind noise instead 😂
Aulric27
Aulric27
ND
Best I can do is the good ol yarn and tape test..
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
Great job, and great writ up! I appreciate the time you put into telling us exactly what you did and how it helped.
j.
MrB4D
Michigan
'24 Trailhunter
After the OEM fix stopped working a year later (specifically driving in the cold with a crosswind) I gave up and went aftermarket.
I will keep a link to this post handy for when I find someone to buy the OEM roof rack off me! Thank you!
