TacoChilly
Dustin
Simpsonville SC
2025 TRD Sport Hybrid
I teamed up with @CAMTuning for my 2025 Tacoma Hybrid, and the second COBB dropped hybrid support, it was go time. I’ve been a long-time COBB fan from my Subaru days, so choosing them again was a no-brainer—then I found out Cam also came from the Subie world, and it felt like fate.
Now, the truck? Oh man… this thing absolutely rips. The torque hits instantly and feels endless. The goofy factory shift points? Fixed. The annoying exhaust drone? Gone. Add in the Sxth Element intake and it’s like the whole setup was meant to be together gifting beautiful turbo noises! Pure magic.
Working with Cam was a blast. He was patient, responsive, and you could tell he genuinely cared about getting everything just right. He kept fine-tuning until he was completely satisfied, and those little tweaks turned my Tacoma into a whole new animal.
Truly appreciate the passion and effort—this truck has never been more fun.
CAMTuning
Cameron
New Mexico
2025 Tacoma TRD OffRoad
I used the words voodoo, black magic, wizardry, witchcraft, alien science. I agree, this is not the same truck I drove home in March.
Are you going to the coffee meetup tomorrow?
Pappy
Albuquerque, NM
I was thinking about it. I need to work on the 4R at some point, but I can do that in the afternoon.
james cole
Bronco
Does the transmission feeling like a CVT gets eliminated?
Meaning the revs hold and the truck acquires speed…
TacoChilly
Dustin
Simpsonville SC
Does the transmission feeling like a CVT gets eliminates?
It definitely helps with that. The “sport” TCM tune really makes it feel like a traditional shift pattern vs the cvt hangout and exhaust drone.
CAMTuning
Cameron
New Mexico
Can you tune the PCM and TCM independently?
It's all through the same flash process, but yes we have full control of upshift and downshift patterns for all drive modes, as well as torque converter lock and unlock. I've spent a lot of time working on the shift patterns and if there's a particular behavior you'd like to see (hold gear longer at lower throttle, downshift with less throttle input, etc) I can do it.
You could even leave all of the power characteristics OEM, and create a file that only changes shift behavior.
That's one of the best features of the Accessport- You can load as many maps as you want to it, and switch between them yourself in less than a minute.
omfg
Oregon
2025 TRD OffRoad
Does the Accessport plug into OBD2? Easy to flash stock tune and remove in case of dealer service?
CAMTuning
Cameron
New Mexico
Sure does, and yes it is. There's an additional cable used in the kick panel to access the CAN, and this is only needed for install and uninstall. The process around 5 minutes to install or deinstall and return to stock. You also don't need the Accessport plugged in for the tune to be on the truck. It's a great tool for gauges and monitoring, but you can leave it at home if you prefer.
I made a video for my customers to show the installation process.
james cole
Bronco
This is going to sound super far fetched…
I like how the ZF 8 speed works, engine and wheels feel very connected contrary to Toyota Aisin Transmission, is it possible to make it operate more connected via what I suppose is early converter lock-up?
CAMTuning
Cameron
New Mexico
We can lock the converter earlier, or make it downshift sooner, giving you more rpm and more swift takeoff. One drawback of earlier lock up with a small displacement turbo engine is that it may not accelerate very well because you're loading the engine up before the turbo is spooled. If you are interested, we can do some tuning on your truck and work to replicate the behavior that you're after. You can pm me if you'd like.
omfg
Oregon
2025 TRD OffRoad
Thanks for the video. Are you able to leave it plugged into CAN in order to change tunes any time, or does it have to be unplugged and replugged into OBD2 during normal operation? Sorry if you answered that in the video, had to watch it on mute.
CAMTuning
Cameron
New Mexico
You can leave the CAN plugged in all the time, but the extra cables are not as tidy as I prefer. You can tuck them up pretty well though, and I had mine that way for over a month when I first got my AP. You only need the CAN cables to install the AP, or uninstall it. To monitor, or to switch between tunes on your Accessport it is not required to keep the CAN cable connected. You can go directly to the OBD2 port.
omfg
Oregon
2025 TRD OffRoad
Great, thanks. Gotta go tell the wife this is what I need for Christmas.
