bmthandrew
Alvin
Alvin, TX
Finally got around to getting the Eibach Stage 2R installed, rides so much better than stock. Haven’t taken it offroad but even just daily driving, sharp turns don’t feel like the whole truck is gonna flip over anymore. Stays planted. However, I did have to remove my front OEM Canadian mud flaps due to rubbing when making turns. Had the East Coast Gear Supply Replacement bearing installed as well, I figured since I had everything removed, I might as well go ahead and get that put in.
Build Specs:
Ceramic Window Tint:
20% front windows
15% rears
70% front windshield
Wheels:
17x8.5 | 6x139.7 | +25 RRW RR7-H
Tires:
285/70/17 Mickey Thompson Baja Boss A/T (SL)
Suspension:
Front: Eibach PRO-Truck 2.0 Coilover (Bottom Thread)
Upper Control Arms: IRONMAN4x4 Pro Forge
Rear: Eibach PRO-Truck Reservoir (Eibach Pro-Truck Springs)
Add-Ons:
OEM Toyota Trifold Tonneau Cover
ARB Rear Steel Bumper W/ Sonar
OEM Sport Hood
TRD Skid Plate with custom TuffSkinz Inserts
OEM Predator Tube Steps
OEM Exhaust Tip - Chrome/Black
OEM Canadian Mud Flaps
ECGS Replacement Needle Bearing
2024 Tacoma Eibach Stage 2R Kit Installed 06C5BEE4-8283-4B99-8222-8C1C434134BA
2024 Tacoma Eibach Stage 2R Kit Installed 713997EB-9255-4D63-A5C1-31E91975AF1F
2024 Tacoma Eibach Stage 2R Kit Installed 226A82FB-E72D-4A86-B590-8DF5078429AD
2024 Tacoma Eibach Stage 2R Kit Installed C3E47477-AC68-493A-931C-AD6FA37B3163
2024 Tacoma Eibach Stage 2R Kit Installed E20C2309-7F4D-4C2B-8C1F-4213A5575D50
2024 Tacoma Eibach Stage 2R Kit Installed EFB7FB07-6889-4FD5-889D-2947F4ECA849
2024 Tacoma Eibach Stage 2R Kit Installed A12F416B-57B8-45ED-B18B-0DBF8F634A42
2024 Tacoma Eibach Stage 2R Kit Installed E1A3537F-77C6-40D0-B50D-8B60BEACDAC3
2024 Tacoma Eibach Stage 2R Kit Installed IMG_3545
bmthandrew
bmthandrew
Alvin
Alvin, TX
Damn dude. That is so clean. I haven't been likely black wheels, but I love those things. Amazing !
Thanks man, I appreciate it! I think the silver bolts give it a good contrast
bmthandrew
bmthandrew
Alvin
Alvin, TX
Honestly one of the cleanest best looking builds I've seen. All subtle, nothing overdone.
The ECGS bearing, was that just preventative?
Thanks brother & yes. I always hear how the stock needle bearing fails pretty quickly after lifting. I’m sure some people get away with never having to mess with it but yeah just preventative.
banyar
juan
bronco123*
tacoma
Looks very nice!! Do you you have measurements in hight before and after the lift?
bmthandrew
bmthandrew
Alvin
Alvin, TX
I never took measurements before and after installing anything :( my apologies! I could try and get some measurements when I get home from work
plasticsnaks
Brett
S Texas
2025 Tacoma Trd Sport 4x4
Turned out really nice!
I recently also installed the eibach stage 2 (non resi) kit along with JBA UCA’s on my 2025 sport. Noticed in your description you mentioned “bottom threads”. Did you lower the spring perch down to the bottom thread?
Only asking because I installed my coilovers with the eibach factory location of the spring perch and ended up with over 3” lift. My front center hub to fender measurement with factory suspension was 21”…..Ended up over 24” after installing the eibach coilovers. After driving around it settled about 1/4” . I lowered my spring perch quite a bit to get the lift down to right under 2”. If it settles more I can crank it back up easily.
I also think this kit rides great and is a great bang for the buck suspension kit.
Congrats on your truck…..looks great!
bmthandrew
bmthandrew
Alvin
Alvin, TX
I installed the front coilovers at factory setting, I assumed I would still have some rake due to the +1” rear springs. Despite having the +1” rear springs, it was squatting hardcore AF. We ended up lowering the perch all the way to the bottom thread and with that, it leveled the truck. Not really what I was expecting but at least I got rid of the squat. If I went higher with the perch, my truck would definitely be squatting. As I put more miles on it, I may have to raise the perch as it settles. I didn’t take any measurements, this was all just what I was visually seeing lol
Also thanks man!
plasticsnaks
Brett
S Texas
Thank you a bunch for replying ! Was wondering if anyone else ran into these front coilovers giving more lift than expected. I’ve read eibach suggests that at factory setting the fronts give around 1.8” to 2” lift which can vary depending on weight of truck.
You probably also got around 3”+ with the factory setting of the spring perch. That would have definitely put you front end high by nearly 2”. I’m now at 2” lift in front and have about maybe 4 -5 threads left until I bottom it out.
I did add a 3/4” spacer to the eibach rear coils to get a total of 1 3/4” rear lift. Wanted to keep close to factory rake. Pretty close now since I lowered the fronts.
Deleted User 412290
Also thanks man!
I think a lot of people unintentionally squat these trucks. There really isn't that much rake if you go by the cab. If you even out the wheel wells, it's squatted IMO.
I had to go to the 1" setting on my 5100s which gave 1.5" at the front wheel well. Put .5" in the rear which gave it it the slightest amount of rake. Maybe between .25 & .5"
AmbyBomb
Nick
2026 Tacoma TRD Sport
How does it ride compared to the stock sport suspension?
plasticsnaks
Brett
S Texas
I’ve only got -100 miles on it post lift. So far, it seems a bit more forgiving vs factory sport suspension. I’m hoping it gets even better after suspension settling and breaking in. My Sport is only a couple months old with 1300 miles. I knew the sport would come with stiffer suspension but my plans were to install the eibach kit to soften the ride and lift 2”.
