TPMS tire pressure PSI not displaying in dash
JED
Southern Tier NY
2015 Tacoma TRD Sport
Tire pressures are not being displayed on the dash but are being shown on the app. ?
Any thoughts?
PaulT
Paul
SC
2024 Taco Sport 4WD
Seems to be a firmware glitch. You can select TPMS to display on the instrument cluster. Turn off the truck for a while and at restart it gets replaced by another gauge. I’ve even tried removing all other gauges as options and TPMS gets replaced with a blank. Ugh.
The only pattern I’ve noticed is that TPMS stays selected if the time between drives is short.
BarryLimited
Kentucky
2024 Taco Limited
My Limited does exactly the same. Got to be a firmware glitch. Also, if I had changed my HUD position it changes back to the default position at the same time the TPMS does. Hope this gets fixed soon. it is very annoying.
M40A1
Virginia
Yup, I have noticed the same issue with mine. Mine reverts to Trip A or B. Issue happens upon a restart.
ldudiaz
Lisandro Diaz
Leesport, PA
24 Tacoma RTD Sport
TRD Sport here and mine does the same.
KevinS54
HHI South Carolina
Just picked up a TRD Sport 2 weeks ago. Same issue.
Has anyone contacted their dealer or Toyota about this yet?
Reactions: JED
RFish
2024 Tacoma TRD off road (soon)
Off road Premium in canada and same issue. Of the 3 different gauge setups I have it only seems to be the tpms one that changes to another or blank. I did notice it blank at start of one drive and then when I switched over it appreaed again.
admo
Adrian
TX
2024 Tacoma I-Force Max Limited
I wrote Toyota. No response.
2024 TRD Sport-Bronze oxide.
Mine is in the app on my phone. Seems to correlate with my pressure gauge, so that will have to do until Toyota fixes the glitch.
Vincent907
North
2024 Tacoma OR 6MT
Seems like someone from TacomaWorld figured that if he has all the connected services accepted from the Toyota app, the TPMS start sticking. Has anyone else tried?
geonerdist
Curtis
Bozeman, MT
This did not work for me, I enabled all connected services. After seeing your link I started paying more attention to this. It seems to be a time duration thing. I switched my left side to TPMS and left it up on the screen during a 20 minute drive. Got home, turned the truck off, and started it shortly after and it still showed the TPMS. However the next morning when I went to leave for work, it had reverted back to Trip B.
