I adjusted my front camera via the on board diagnostic service menu. I adjusted it +165 while parked in a place where there were lines and it all lined up. Although for some reason the view adjustment button is now greyed out and I can’t access it anymore.
How'd you get to this menu system?
rijc99
Key on engine off - turn audio off - turn display off - swipe right 5 times swipe left 5 times.
Function check - Canera settings - View adjustment.
Make sure to park where there are plenty of straight lines in front and around your car for alignment purposes. Do the adjustment in one shot or don’t save.
Mine is greyed out because I already made an adjustment. So do it in one time.
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2704
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2705
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2706
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_2707
taco4moro
Los Angeles
2024 Tacoma TRD ORP
wow thanks for finding this, the dealer was going to charge me a couple hundred $ to fix.
Which camera bracket did you use? Hoping to be able to fix the camera alignment perfectly as having the 360 view off bothers me so much.
rijc99
I used Rave’s bracket. Good luck with your alignment. Find a flat place with a bunch of lines or lay some stuff down and take your time.
Castiglione
Maui
2024 Toyota Tacoma
Once you adjust and save it, you need to reprogram the circumference monitoring system again to readjust it.
Hello, how do I reprogram the circumference monitoring system? Also, can you tell me how I’m suppose to flip my camera view through the settings? I tried doing the plus and minus but it’s not flipping my camera. Thank you in advance
hemlockz
‘24 TRD Offroad 6MT
I used the bracket but didn’t flip my camera (rave style) because I didn’t have a way to change the camera to upside down. I think the problem with that is the camera is not symmetrical so it ends up too skewed-exactly like gurvey said…. This can’t be a matter of adjustment, I gotta do what he did and physically flip it a tech stream it.
2024 Tacoma Heritage Grill Camera Swap - Observations IMG_0443
rijc99
I had to go all the way to positive 165 to line up.
Sounds like I might need to access this adjustment menu to fix my front camera line up. Shows "short" since doing the change with Rave bracket.
2024 Tacoma Heritage Grill Camera Swap - Observations PXL_20250217_211122970
2024 Tacoma Heritage Grill Camera Swap - Observations PXL_20250214_153415644
rijc99
The angle is different so you need to adjust it plus (or minus) by quite a bit. That will bring it back in correct alignment.
shantdiarbi
Shant
Rockville, Maryland
did you ever end up adjusting it yourself? I have the exam same issue after using the rave camera bracket. Let me know thanks!
rijc99
+165 and it aligned in my case. Only save it if you’ve gotten it aligned. You get one save.
shantdiarbi
Shant
Rockville, Maryland
Got it. And this is the only adjustment you had to make? Nothing to do with the 360. Just the front camera +165
