dunder
dunder
'26 Cayenne Turbo, '25 MB CLE53
shouldn't have thrown codes, the fuel system & sensors should have adjusted for the extra air, adding more fuel to adjust....
just like if your in fact restricting airflow now, the system will sense that & compensate in a bad way...
just cuz its not throwing a light, doesnt mean its not leaning out...
I’m not restricting air flow, the second opening allows just as much, if not more than the snorkel. I assume Toyota did this to allow people to completely blocked off the snorkel. It’s obnoxious. Unfortunately, too much air is a problem for some of the hybrids since I’m not the only one who had code issues with a CAI.
Nelly12
Nelson
Oceanside, CA
Tacoma - Trailhunter
How's the car running. Any issues so far? I just purchased a TH and am interested in doing something similar to reduce noise.
dunder
dunder
No issues other than less than expected mpgs: 16/18. I’m only just over 1k on the odometer.
Awger
Kelowna BC
24 Tacoma
Has anyone tried replacing the scoop at the top of the intake with a cyclone filter cap or something like that? I don’t have the snorkel on my Tacoma, but I was thinking of having one installed at some point down the line.
I wonder if that would make any difference with the sound.
I'm trying to do something similar. I've got the lower rubber cap removed and tried to insert an inflatable toy ball into the top of the snorkel and aired it up. It's blocking most of the air, but now I'm worried it'll deflate over time and go into the air box. I really only want the snorkel noise gone for road trips with the surf-wife, but I'm not sure what I'm proposing is a real solution.
Nelly12
Nelson
Oceanside, CA
Surf-wife? You in SD?
Best solution I've seen so far might be to install the air box from the pro and completely block intake from snokel. Would render it useless but I belive the installl/removal is somewhat easy/quick.
Awger
Kelowna BC
24 Tacoma
Lol, no not in SD...
Yeah, I'm hoping to be able to use it when she's not in the rig... That turbo noise is too fun!
Gonna try a plumbing balloon test plug. It's got a loop that I can mechanically fasten to a zip tie to the louvers of the snorkel.
Nelly12
Nelson
Oceanside, CA
Send pics when you do it. I'd be interested in see it done.
Awger
Kelowna BC
24 Tacoma
Cool!! How is the sound after install?
Quieter... Maybe 40-60% better. I'm surprised its still making any noise to be honest.
I think the only way to completely eliminate the noise is to close the outlet box from under the hood, but that solution is a bit too permanent for me.
Nelly12
Nelson
Oceanside, CA
I'm right there with ya. Could you provide a list of the items you used for this mod? Any links on where to get it? I'm really interested in trying this out!
Awger
Kelowna BC
24 Tacoma
I just used a 3" plumbing test ball and a zip tie. You can get the test ball from any plumbing specific store.
Awger
Kelowna BC
24 Tacoma
Update: I've messed up my MAF sensor with oil from the air filter after making this change. Dealership replaced the sensor. I'll be looking for a TRD pro intake to swap out now.
I can't recommend the modifications I've made to block the snorkel.
Nelly12
Nelson
Oceanside, CA
Thanks for the update. Any idea if replacing current intake with the TRD pro would void warranty? This swap way my initial plan to help with noise.
Awger
Kelowna BC
24 Tacoma
I'm trying to get the dealership to do that work. It shouldn't if they do it.
