Removing/hiding mild scratches on dash by AC knobs
Noticed these two scratches on delivery of my Tacoma and I'm wondering if there are recommendations on how one might eliminate or effectively make them disappear without having to figure out a part# and tear down sequence to replace the trim panel itself.
Neither removed by glass cleaner and while you can't feel the left one, you can catch your fingernail on the right one.
And before anyone says the asinine, no I was not going to refuse delivery after a 3mo wait for something this minor.
Looking for input from those having already dealt with similar on this truck or other vehicles
Much appreciated!
2024 Tacoma Removing/hiding mild scratches on dash by AC knobs eeff73cd-cd15-4cd1-9161-9d8605fba37f
2024 Tacoma Removing/hiding mild scratches on dash by AC knobs 9d865606-23e3-468d-be17-a0310c08ea54
Bluznvice
West
Yeah, not enough to refuse delivery, but things like this sure do bug the shit out of you.
The interior plastic on this truck is very prone to scratching and marking. I use 303 protectant for the interior and black exterior parts.
Hopefully you noted it on delivery and they'll replace it
I have smoothed out scratches in plastic similar to the ones you have with a mild rubbing compound. I also have some plastic polish that I found on Amazon which does a good job of removing surface scratches.
I would probably try the plastic polish first and those don't look bad enough to replace the panel IMO.
Any specific product recommendations or links?
They noted it when I sent photos, but the dealership is over 900mi away. Wasn't going to have the truck sit there or drive it back to replace. If it has been really gouged or broken - different story.
@Baltimore Search Amazon for Novus Plastic Polish. They have a lot of different kits. I just had the two part one and it worked well. I successfully removed scratches from a lot of plastics with that kit.
Forgot to follow up on this. I ended up ordering the Novus. The mild scratch rub (step2?) solved the lighter scratch and diminished the heavier one. I opted not to lay into the heavier one with heavy scratch rub (step1?)... just made me too nervous in the moment.
Thank you for the recommendation!
Your are welcome. That is what I usually do too. I see what the mild scratch remover will do and then only use the more aggressive one when I absolutely have to. I'm glad it worked well for you.
Cabby30
CA
2024 DCLB TRD OR
Anybody’s driver side door looking like mine? ?
Mine has no scratches at all but on the bright side that strip pops right off and you can replace it with a TRD one if you wanted.
dvrgz
Los Angeles
We’ll see how they hold up. Sanded them and sprayed them with plasti dip. Like I did with the front emblem.
2024 Tacoma Removing/hiding mild scratches on dash by AC knobs IMG_8379
2024 Tacoma Removing/hiding mild scratches on dash by AC knobs IMG_8340
Good job - they look way better than they did. I don't see how they can hold up any worse than the parts Toyota put in from the factory.
